I swapped a crvtec in my freinds 2000 si and for some reason cylinder 3 is missfireing. we changed the plugs, wires, cap, rotor, and the coil in the dist and Honda put on a new timing belt and they said it was "dropping a cylinder" and they didnt know why. they sugested a valve adjustment or possibly the ecu was having problems running the motor due to low compression. does their sugestions sound resonable? what would cause this?
97 Civic HX Black coupe 2000 B16a2 DC 4-1 ceramic header apexi ws catback AEM CAI H&R sport springs with kyb struts Full Si interior Si spoiler and tails Si gauge cluster 99-00 climate control 99-00 front end <a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=266\' target=\'_blank\'>http://www.hondaswap.com/gallery/browse.ph...hp?album_id=266</a> |
All I want is a b16, and I hear about you rich guys ripping them out to put something else in...I wish I had more $$$
bump __________________
The swap is completed. Dented oil pans will kill vtec. Now boosted! Vouches: Wanderinman |
no one has ANY ideas???
#5 |
Have you tried moving the injector from cylinder #3 to another cylinder and seeing if the other one misfires? Probobly not the cause, but it is an idea.
02 Sebring Silver / Red S2000 |
#6 |
compression was checked on the block when i purchased it a month or two ago and it was fine. i havent checked the injectors they came with the 99 crv longblock that i bought. i will switch them around and see if the problem moves with it. also the firing order is correct.
Thanks __________________
#7 |
Are you still using the Si ECU? Check the compression with the new head on it. and yes, adjust the valves. I had a Toyota with a new engine done by a reputable guy come by dropping two cyl. It was really screwy valve lash, it has to be extreme, but if the valve events are off, no compression. Pull the plugs and read them.
1320 Motorsports Athens,GA <a href=\'http://www.1320motorsports.com\' target=\'_blank\'>1320 MOTORSPORTS</a> |
#8 |
yeah still using the si ecu on this swap. im gonna do a valve adjustment and check the injectors this week and if its not working i'll have the compression checked again.
Thanks Rick __________________
#9 |
It will run, but a stock Si ECU will not provide the right fuel for this setup. You need to look into.... Preferrably Hondata, or at least a V-AFC. If this is old hat to you, don't get insulted....but be sure to do the compression test hot and the valve adj. cold, not "my temp gauge says cold", but a thermometer in the valve train reading under 100 degrees. Otherwise your valve lash will be off later.
#10 |
ok, so i did a valve adjustment and it didnt change, then i swapped injectors and nothing. i checked compression and cylinder 2 is a bit low and three is really low 1 and 4 are fine. what would cause low comp? do you think the head gasket isnt sealing right? i torqued it down to spec maybe i need to get the head shaved it could be warped or something. that is what i am thinking. is there any other reasons for low compression? compression was checked on the crv longblock when i bought it and it was good but dropped when i put on the si head.
#11 |
Neighborhood Lush
the head could be warped or the head gasket could be blown. you should pull the head off and look (its gonna have to come off anyway) you might end up needing the block shaved and the head milled, but check it all for straightness before you do anything.
also, did honda put the right head gasket on? i dont know which one that engine is supposed to take, but im sure its not just a CRV or just a Si timing belt... there are lots of ways you can loose compression, valves not closing all the way, head gasket, hole in a piston, warped head, cracked head etc... make sure you check all these things if you pull the head off, good luck with it. -Chris __________________
EG2 Drink Beer. |
| Digitally Imported Trance | Cashizslick | Members' Lounge | 12 | 02-20-2005 04:40 AM |
| 2000 Civic SI w/ 2000 JDM ITR Swap in TN | Red94CivicDX | Vehicles: For Sale/Trade/Wanted | 3 | 03-28-2004 09:35 AM |
| How to Compute the Compression Ratio of a motor | pissedoffsol | General Tech Articles | 0 | 01-12-2004 01:41 AM |
| 2000 Dx With 2000 B16 | skeeterdx | HYBRID -> EG-EK / DC | 1 | 05-21-2003 04:53 PM |
| My 99 Civic Coupe Or Trade For A 2000 Integra Gsr | nash | HYBRID -> EG-EK / DC | 6 | 04-07-2003 11:44 AM |
