'91 B18B in '99-'00 Civic EX
Old 11-13-2003, 01:53 AM   #1
DiSbaDbOi is off the scale
I have a 99-00 civic ex and I was planning on doing a '91 B18B motor swap. But I have no idea what kinda wire harness, mounts, and ecu to use. I done a search but I couldn't find nothing that I was looking for. Can some tell me or show me a site that has all these information. I would like all these information ASAP. Thanks~!!
DiSbaDbOi is offline   Reply With Quote
Old 11-13-2003, 01:59 AM   #2
Member of the 20 nut club
E_SolSi's Avatar
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
that engine will be a BITCH to get wired in there.... and the tranny wont work
Old 11-13-2003, 02:05 AM   #3
is it really that bad? I know the tranny won't fit, i'm getting a hydro tranny.
Old 11-13-2003, 01:25 PM   #4
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
It isn't hard until the wiring part comes along, and in 91' they had a b18a1 not b18b1, BTW if you haven't already bought the engine, DON'T BUY IT. Buy one from a 96+, then it should wire up fine, and bolt right in (correct me if I'm wrong)
92civicb18b1 is offline   Reply With Quote
Old 11-13-2003, 03:04 PM   #5
Yea, thats why i post this topic, because i have no idea how to wire everything. and yea I had already bought it.
Old 11-13-2003, 03:22 PM   #6
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
sucks man, pull the intake mani, and buy a new one from a 96+ integra, no you can't use the one that came on it. you also need to use your stock wiring harness, but you will have connectors that wont go anywhere because your harness is for a vtec motor.
wait i'll make you a list of things you need-
intake mani from a 96+ teg.
throttle body from a 96+ teg
tranny from a 94+ integra or a 92+ civic del sol VTEC (only the VTEC model, no s or si)
you will need all the sensors from your old motor, and your old engine harness.
if you live in a smog state you wont pass because the block is too old.
you will also need the mounting hardware from a 96+ integra gsr.
shift linkage from a 94+ integra
your stock injectors will wok fine too, so you need those.
thats all i can think of right now, but the intake mani and throttle body are non-negotiable, you have to replace them, and you will realy want to use your stock harness, and if you can get an obd2b- obd1 conversion harness and find an obd1 pr4 or p75 from a manual tranny integra.
saturn_boy96 is offline   Reply With Quote
Old 11-14-2003, 01:39 AM   #7
thanks saturn_boy, that was a hold lot of information you gave me. What do you mean by vtec only tranny? Can't I use any B-series hydro tranny? Also, what mounting hardware from 96+ gsr?
Old 11-14-2003, 01:37 PM   #8
freshclive is off the scale
he means just that not all del sol's are b series only the 94-97 del sol VTEC(b16a2,3),
rest are all d series.
freshclive is offline   Reply With Quote
Old 11-14-2003, 02:00 PM   #9
Oh I get it, but I still need more information about the topic. Thanks
Old 11-14-2003, 02:32 PM   #10
you need the motor mounts from a 96+ integra gsr, or a has port mount kit.
i think you will also need a lower divier side motor mount bracket from a 96+ integra gsr.
freshclive: thanks, thats exactly what i meant.
Old 11-14-2003, 02:51 PM   #11
MaliWho97 is off the scale
Plus, its Illegal to put a motor from a lower OBD Bracket in your vehicle. Example, OBD2 car w/ OBD1 motor, illegal. OBD1 car w/ OBD2 motor, legal. Get me???
MaliWho97 is offline   Reply With Quote
Old 11-14-2003, 04:08 PM   #12
only in smog states.
Old 11-15-2003, 12:49 AM   #13
People have been telling me I need 99-00 civic si motor mounts, besides the a/c bracket..i need the 96-97 del sol bracket.
What do you mean only in smog states? I live in Calfornia
Old 11-15-2003, 02:13 AM   #14
E_SolSi's Avatar
if your in calli and you try to swap that engine in that car they will castrate you
Old 11-16-2003, 01:32 AM   #15
will it still be illegal if i swap that motor in but with a vtec head? does it make any difference?
Old 11-16-2003, 01:33 AM   #16
E_SolSi's Avatar
the Peoples Republic of California doesnt allow head swaps
Old 11-16-2003, 07:35 PM   #17
The Trisexual
That sucks man, You can't drive your car legally in California with that motor. But you might be able to trick them, get the block restamped, use ALL obd2 parts (including the head), and make sure you'll pass emissions. Or you can just buy an EG and drop it right in.
Old 11-16-2003, 10:14 PM   #18
hondapwr is off the scale
for one, if you are smart and want to save money, go to hasport, pick up a Cable Tranny Conversion kit for like 130 bucks, then pick up a 90-93 tranny which will cost you like 1/3 what a hydro tranny will. You need the rear tranny mount for a 99-2000 civic si. You need linkage from whatever series tranny u use. wiring won't be easy, but you can always consider an obd1 conversion harness which can be purchased from skunk2 which will also allow you to save some serious dough. You should try to get in with some guys that live near you that can help you with the swap. It won't be easy and I would suggest getting some help from someone more experienced. Everyone knows someone who knows someone that can swap honda motors for CHEAP.
Jason
hondapwr is offline   Reply With Quote
Old 11-18-2003, 01:26 AM   #19
InsaneCivicSedan is off the scale
Send a message via AIM to InsaneCivicSedan Send a message via Yahoo to InsaneCivicSedan
I believe the 91 LS was a b18a... the b1 was from 94-95 in obd1 and 96-01 which is obd2.... to use the B1 in your car all you need is mounts from a 99-00 si and it will bolt right in and plug n play.... only wires you dont connect are vtec (of course)......
InsaneCivicSedan is offline   Reply With Quote
Old 11-19-2003, 12:43 AM   #20
what do you mean plug n play? I can use my wire harness off my SOHC for the LS motor?
Old 11-19-2003, 01:02 AM   #21
Retired OG
Ride:  Integra, Tahoe
kyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura about
Send a message via AIM to kyleirwin
plug 'n play just means that you can just plug the harnesses in and won't have to do any wiring.
BTW: your avatar is the shit.
kyleirwin is offline   Reply With Quote
Old 11-19-2003, 01:16 AM   #22
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
im still trying to figure out how you scored a b18b1 3 years before they were in production????
Old 11-19-2003, 02:26 AM   #23
what do you mean plug the harness in without doing any wiring? So I don't have to use the LS wire harness? I can use my SOHC wiring harness?
Are you Talking about my avatar? If so, THANKS~!
Old 11-19-2003, 02:39 PM   #24
yeah, now that i look at it i too am confused.
DiSbaDbOi: what motor do you have?
Old 11-20-2003, 12:21 PM   #25
b18a motor off a 91' LS integra
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 12:03 PM
Decoding VIN Numbers pissedoffsol General Tech Articles 0 01-11-2004 07:48 PM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 03:43 PM
All This Reference Material, And No Cel Code Chart Slo86GT Members' Lounge 5 06-13-2003 09:31 AM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 04:32 PM
