93 CX Hatch W/ GSR no FUEL!!!
Old 04-04-2009, 12:36 PM   #1
92CivicHatchCxBORNINCALI
lewellgd's Avatar
Ride:  1992 HONDA CX HATCH
Rep Power: 7 lewellgd is on a distinguished road
Send a message via MSN to lewellgd
Exclamation 93 CX Hatch W/ GSR no FUEL!!!
i bought a 93 cx refed for gsr already was wired and hooked up but had rod knock so got it cheap. put everything together and back in motor turns over everything fine but no fuel pressure at all nothing. cant even here the pump kick. what do i need to check any ideas thanks.
If you find my info helpful plz leave rep.
(\__/)
(O.o )
This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
lewellgd is offline   Reply With Quote
Old 04-04-2009, 12:53 PM   #2
AHHVTEC's Avatar
main relay
Old 04-04-2009, 12:57 PM   #3
lewellgd's Avatar
and thats up under the dash right. i dont see why that would just decide to go out all the sudden. but ill check it. is it under the dash.
(\__/)
(O.o )
Old 04-04-2009, 12:58 PM   #4
AHHVTEC's Avatar
its a start, see if you can hear it click when you cut the key to the on position
Old 04-04-2009, 01:03 PM   #5
lewellgd's Avatar
Yeah something does click.
(\__/)
(O.o )
Old 04-04-2009, 01:04 PM   #6
AHHVTEC's Avatar
well the main relay is prolly good then.your pump might have went out
Old 04-04-2009, 01:06 PM   #7
AHHVTEC's Avatar
also check and make sure your pump is getting fire to it
Old 04-04-2009, 01:06 PM   #8
lewellgd's Avatar
they can just go out out of know where like that how much is one of those and is there any way to test it
(\__/)
(O.o )
Old 04-04-2009, 01:12 PM   #9
lewellgd's Avatar
do i turn the key on and then test light it. which color wire should have power
(\__/)
(O.o )
Old 04-04-2009, 01:29 PM   #10
AHHVTEC's Avatar
yeah have the key on, and im not sure but one of them lol just test both for fire
Old 04-04-2009, 02:14 PM   #11
lewellgd's Avatar
is there any chance it could be a bad ecu
(\__/)
(O.o )
Old 04-04-2009, 02:22 PM   #12
lewellgd's Avatar
really want to get this car running i think the relay is good i havent checked the pump for power but if it does have power then the pumps gone right. but if it dosent have power does that mean bad ecu or relay.
(\__/)
(O.o )
Old 04-04-2009, 03:21 PM   #13
lewellgd's Avatar
Got power to fuel pump but the light on the tester was very very dim
(\__/)
(O.o )
Old 04-04-2009, 03:55 PM   #14
Dark93DX's Avatar
Rep Power: 10 Dark93DX is on a distinguished road
If the relay is fine, the pump is getting 12V, and you dont hear the pump run when you turn the key to the on position, then its most likely a bad pump. In the past when I've had a pump going bad sometimes tapping on the fuel tank would get it to start, but that only works a couple times.
BTW, how do you know there is no fuel pressure, do you have a gauge on there?
K20Z3 EG - Installed, waiting for Kpro
LSD w/ 4.764 FD
B18A CRX
Dark93DX is offline   Reply With Quote
Old 04-04-2009, 04:55 PM   #15
lewellgd's Avatar
checked relay and its good tested it on another hatch. got power to the pump when i put the tester on it there was a very dim light. so the only other thing it could be is the pump right.
(\__/)
(O.o )
Old 04-04-2009, 05:11 PM   #16
AHHVTEC's Avatar
sounds like a bad pump
Old 04-04-2009, 05:12 PM   #17
lewellgd's Avatar
just tested the pump in another car and its good to?? What else lol
(\__/)
(O.o )
Old 04-04-2009, 05:14 PM   #18
AHHVTEC's Avatar
so you took your pump out and tested it ?
Old 04-04-2009, 05:15 PM   #19
lewellgd's Avatar
i took it out and put it in another hatch i have and it workes and started just fine
(\__/)
(O.o )
Old 04-04-2009, 05:16 PM   #20
AHHVTEC's Avatar
yeah try to borrow a ecu from someone then and see if thats it
Old 04-04-2009, 09:42 PM   #21
lewellgd's Avatar
hey figured it out i traced the wires from the fuel pump and someone who had it before me wired a switch for the fuel pump underneath the shift boot. i guess so no one would steal it or something but figured it out and started up just fine. Thanks all for the help.
(\__/)
(O.o )
Old 04-05-2009, 09:48 AM   #22
Ride:  87' honda prelude
Rep Power: 5 Old$koolLude has a spectacular aura aboutOld$koolLude has a spectacular aura about
i have the same prob with my 2nd gen prelude
Old$koolLude is offline   Reply With Quote
Old 04-05-2009, 12:13 PM   #23
Rep Power: 11 BrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura about
very deceiving quote. I completely destroyed half of my garage trying to verify this... thx a lot AHH :P
BrokenRex is offline   Reply With Quote
Old 04-05-2009, 12:22 PM   #24
AHHVTEC's Avatar
it was junk anyhow lol
Tags
b18, civic, eg6, fuel, gsr, hatch, hatchback
92 GSR b17 into 96 DX EK hatch, fuel problem, help please. shandonwall HYBRID -> EG-EK / DC 3 09-15-2008 07:52 PM
wtb: Fuel box relay?? 93 hatch MJ93Hatchback Parts: For Sale/Trade/Wanted 4 07-30-2008 09:43 PM
Changing a fuel pump in 89 ef hatch. 5speed4life HYBRID -> ED-EF / DA 5 08-02-2005 11:33 AM
91 hatch with b16 Fuel Injectors to Buy???? Jdubspeeds General Tech and Maintenance 1 12-25-2003 01:06 PM
WTB: Fuel Pump '91 Civic Si hatch Blanco Parts: For Sale/Trade/Wanted 2 11-18-2003 09:51 PM
