93 Del Sol Swap
Old 05-12-2003, 06:59 PM   #1
Rep Power: 0 del sol is off the scale
hey first time caller long time listner, i have a dumb question, to swap a b series (ls, si, gsr) into a del sol with a 1.5l pos engine do i have to swap:
mounts(or use stock mounts)
harness(or run vtec to seperate switch)
axles(or are they the same)
spindals(if i have to change axles)
shifter linkage........
i did a b16a1 swap into my 91 hatch and had to swap everything i just listed.
also if i was to swap an ex motor+trans would i need anny extras? thanks for all your help............
del sol is offline   Reply With Quote
Old 05-12-2003, 07:41 PM   #2
Retired OG
Ride:  Integra, Tahoe
Rep Power: 43 kyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura about
Send a message via AIM to kyleirwin
for a b-series swap into a sol you can use stock mounts from a 94+ integra, 99-00 civic si, or a combo of both depending on the engine you're swapping. if you're swapping a vtec engine in (b16, gsr) then you'll need to run a few wires for vtec, you can either wire them into the harness or run them stright to the ecu (i believe). you'll need to replace the axles, the easiest to find/use are any from a 94+ teg. and for shift linkage... you'll need one from a del sol vtec model. the linkage from a s or si WILL NOT work.
i didn't understand that question. what ex motor? and into what?
Kyle I. Collins, PmD.
kyleirwin is offline   Reply With Quote
Old 10-31-2007, 05:11 PM   #3
Rep Power: 8 Legend_master is off the scale
I know this is an old thread, but do I need the TQ rod and Shift rod from the Vtec model or just the shift rod?
http://img.photobucket.com/albums/v6...r/63cd2e07.jpg
http://www.cardomain.com/ride/1889092
1986 Accord
LS/Vtec and Full
Suspension Upgrade
11" rotors Type R Calipers
Legend_master is offline   Reply With Quote
Old 10-31-2007, 05:29 PM   #4
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
both. its usually sold as one piece anyway
Old 10-31-2007, 05:32 PM   #5
Awsome, thanks.
1986 Accord
LS/Vtec and Full
Suspension Upgrade
H22AdelSol's H22A swap guide. H22AdelSol HYBRID -> BA-BB /CA-CD 14 08-04-2008 09:53 PM
Del Sol S D15B7 to D16y8 swap question oakley2002@cox.net HYBRID -> EG-EK / DC 1 01-21-2004 01:32 PM
2nd gen Integra Swap Info pissedoffsol Swap Articles 0 01-12-2004 02:16 AM
1st gen Integra Swap Overview (da) pissedoffsol Swap Articles 0 01-12-2004 02:15 AM
