This is a discussion on 94 Civic LS swap Mount Questions in the HYBRID -> EG-EK / DC forum
Is it neccesary to to have the front AC mount stopper Bracket and Bolt down? Thats a expensive piece and I don't see it used in many other swaps of earlier models....
| | #1 |
| Is it neccesary to to have the front AC mount stopper Bracket and Bolt down? Thats a expensive piece and I don't see it used in many other swaps of earlier models. |
| | #2 |
| im just using the two top side mounts and the rear mount |
| | #3 |
| Well the A/C bracket is actually a torque bracket that you really dont need but it does help. I ran my car without it for a long time after I removed my A/C. |
| | #4 |
| if your using swap mounts then chances are you don't need it. Specially since most swap mounts are solid Urethane. |
| | #5 |
| I just did the same swap and did not use the a/c mounts or the one on the other side either. I have noticed no difference either. I used the factory motor andtranny mounts also. I intend on changing to the hasport mounts eventually. But to answer your question, you dont really need them. |
Similar Threads | ||||
| hasport engine mount 92-95 civic b18 swap | RSS-Bot | Auctions | 0 | 12-06-2007 11:03 AM |
| All Swap Info for EF | Riceras | HYBRID -> ED-EF / DA | 2 | 02-07-2005 02:20 PM |
| civic engine swap questions | tamber92civic | Members' Lounge | 6 | 02-09-2004 11:17 PM |
| 6th gen Civic Basic swap overview | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:14 AM |
