96-98 vs 99-00
Old 10-24-2003, 06:52 PM   #1
spOonPLS. is off the scale
Are 96-98 ek motors mounts the same as a 99-00 ek motor mounts?????
And are 99-00 civic the same as 99-00 si motor mounts????
spOonPLS. is offline   Reply With Quote
Old 10-24-2003, 08:38 PM   #2
bump
Old 10-25-2003, 03:27 PM   #3
noobvang is off the scale
96-00 civics are the same.
99-00 SI have different mounts, looks the same but have different bolt pattern. Only one you can reuse is the top trans mount bracket.
noobvang is offline   Reply With Quote
Old 10-25-2003, 05:19 PM   #4
redhatch92 is off the scale
Send a message via AIM to redhatch92
if your doing a swap stick with the mount that match the motor and the trans it will save you a lot of headachs
redhatch92 is offline   Reply With Quote
