97 obd2 b16a2 swap 2nd o2 question
Old 07-21-2006, 05:44 PM   #1
Rep Power: 0 EKRBoi is on a distinguished road
Default 97 obd2 b16a2 swap 2nd o2 question
i have a 97 hatch with a 99 b16a2 in it.. im running an obd2 p72... i got the car like this for a great deal and have been working its kinks out... The dash was swapped from a later model ek also and for some reason the dash sub harness did not have the 2nd o2 harness in it or the sensor at that.. no big deal.. im a mobile electronics professional.. wiring is nothing... so i sourced out the sensor.. the o2 plug and wired it up myself as follows
o2 side \ ecu side
green - A6 (blk/wht)
white - D14 (wht/red)
black - D13 (grn/blk)
black - A11 (ylw/blk)
why on gods green earth honda made both heater wires black ill never know... but anyhow... ive tired both of them both ways and i cant get rid of code 65 (secondary o2 heater circuit) .. i have lost all faith in honda-tech almost i posted many many topics about how to tell which is which and never could get an answer on that or anything really...and couldnt find anything on the net. i finally found a post somewhere that said if they were crossed the car just wouldnt run for long and just to switch them which i have done.. the car never cut off but i kept getting the CEL after about 20-30 seconds of the engine running with the wires both way
s.. as i stated before i do mobile electronics so i did take a multimeter to it and d13 (sensor ground) is a ground... im getting proper voltage on d14 (signal) im not really sure how to test a6 to see if its functioning right.. and of course a11 ia 12v switched... any suggestions?
EKRBoi is offline   Reply With Quote
swap question Blackhatch94 HYBRID -> EG-EK / DC 1 11-13-2003 01:21 AM
00 Si (b16a2) to 93 si Swap ?'s marklar182 HYBRID -> EG-EK / DC 2 08-05-2003 09:23 PM
Noob here, Question on b18c swap alllooksnnogo HYBRID -> EG-EK / DC 2 07-12-2003 01:31 PM
Jdm Obd2 Swap Situation brixity ECU's, Electronics, and Tuning 1 04-09-2003 02:42 AM
