99 ek with ls vtec problem
Old 02-01-2008, 01:34 AM   #1
Rep Power: 0 solobomber is on a distinguished road
Default 99 ek with ls vtec problem
hello everyone
ok so heres my story. recently i build a ls vtec motor using a b18a1 block and a b16a2 head also a gsr tranny. im running the obd2 si ecu. heres the problem with my motor it started just fine but with high rpms and it wont idle for jack squat. Its not showing any engine code what so ever until i unplug a sensor. i by passed the crank angle senser re wired the distributor but i broke my knock sensor and its currently not plug in can anyone give me some ideas to where the problem might be at
solobomber is offline   Reply With Quote
Old 03-02-2008, 02:31 AM   #2
so now i found the problem i use a code scanner and the scanner is throwing p0505 iac system. ive checked the iacv but nothing idk what else to look for help
Old 03-05-2008, 10:33 PM   #3
Rep Power: 0 xlasianizelx is on a distinguished road
try replacing the idle air control valve, or clean it, and if you have time, clean out the intake manifold, throttle body, and intake sensors...
xlasianizelx is offline   Reply With Quote
Old 03-12-2008, 06:59 AM   #4
gsronroids's Avatar
Ride:  92 civic si gsr
Rep Power: 6 gsronroids is on a distinguished road
you can clean the iac with simple carburator cleaner just make sure you dont misplace any of the little screens or rubber seals that tend to pop out
gsronroids is offline   Reply With Quote
Old 03-12-2008, 02:54 PM   #5
drive it like U stole it
custompainter's Avatar
Ride:  99 dx coupe y8, 94 ex coupe z6, 89 teg zc,
Rep Power: 11 custompainter is on a distinguished road
i just fixed the same problem .:FFS TechNet:.
use this link and scroll down to the OBD2 A or B and do the three-wire IACV repin
i had a high ideal and the CEL was coding for a IAC problem did this wire switch this morning and it dropped the ideal down and it's been running great all day
hope this helps
custompainter is offline   Reply With Quote
Old 03-12-2008, 08:25 PM   #6
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
you will blow that engine if you keep using that ecu.
buy a chipped p28 or = and have them remove all the sensors you can (if you dont ref)
http://pandora.com/
Old 03-13-2008, 12:34 AM   #7
Rep Power: 16 killercannible will become famous soon enough
In any state it is hard to get it smogged by tailpipe instead of plugin for obd2. However if you ask some garages are happy too and it is legal. Run obd1 and unless your in cali keep looking for a garage that will tailpipe it for you.
Got my swap!!! Needs to be faster.
killercannible is offline   Reply With Quote
b16a vtec b20b block idle problem microshit Civic and del Sol - EG and EK 4 02-02-2008 06:06 AM
b16a obd 0 tune up parts list feet_ HYBRID -> ED-EF / DA 6 12-27-2007 08:50 PM
SOS! SWAP problem - JDM H23 VTEC engine Atrevido Members' Lounge 2 01-19-2005 02:30 PM
Part Numbers for 89Si/B16 OBD0 Swap steelbuster Swap Articles 0 11-16-2003 07:36 PM
