About to buy motor
Old 01-20-2004, 07:52 PM   #1
Rep Power: 15 Pewble is off the scale
Send a message via AIM to Pewble
Is there a USDM b16 that would plug right into my car? without the OBDII harness....?? I dont want a JDM motor because I also need it to last long... JDM motors will knock with our gas and without octane additive, correct? Or will a JDM b16 be ok with premium gas...?
My car (95 civic dx coupe) is OBDI Right? Thanks
Pewble is offline   Reply With Quote
Old 01-20-2004, 09:10 PM   #2
Rep Power: 0 Milehigh is off the scale
The compression of the JDM b16 is only slightly higher than the USDM motors, so you'll be fine on pump gas. Just get the highest octane available in your area. You could get a JDM OBD1 B16a for fairly cheap, which would pretty much bolt and plug right in.
Milehigh is offline   Reply With Quote
Old 01-21-2004, 12:46 AM   #3
Rep Power: 14 highlife is off the scale
A del Sol is also OBDI B16, u dont need to worry about OBD harness with the Del Sol engine
highlife is offline   Reply With Quote
Old 01-21-2004, 05:29 AM   #4
BadASS! I Ill get the JDM one then. thats awesome news. Hey.. is it easy to take apart the motor and re-assemble? after cleaning the internals? can this be done by hand?
Old 01-21-2004, 08:52 AM   #5
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
no offense, but you sound like someone who shouldnt be taking apart a motor.
theres really no reason to take it apart and put it back together, unless you're putting in pistons or somethin.
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 01-21-2004, 09:49 AM   #6
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
if you are seriously thinking about dissasembling your engine. get a helms manual. Helm Inc. the best 60 bucks you could spend on your car. i would be a good idea to get one for both the engine and for your chassis.
as for the motor, pretty much everyone here reccomends hmotorsonline --->HMO and for good reason, they are pretty much the best as far as quality and customer service.
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 01-21-2004, 03:51 PM   #7
Ok... Yes I know im someone who shouldnt disassemble my motor, but my dad knows how... Also, I can get the head ported out and a valve job really cheap. I want to buy the motor now so I can work on in until spring. Put in ARP head studs and bolts, and cams. I was wondering if it were to be worth it to polish any internals?
and umm.. which motor should I get?
http://www.hmotorsonline.com/shop/sc2000se...page&item=30002
http://www.hmotorsonline.com/shop/sc2000se...page&item=30005
And why is the SiR-I motor so much cheaper? Thanks For your help.
Old 01-21-2004, 03:58 PM   #8
Umm just noticed that the first b16 there has a cable tranny and the second has hydraulic.. theoretically, could I use either one? or is hydraulic better. My car is hydraulic right now...
Old 01-21-2004, 04:06 PM   #9
Rep Power: 20 ef9civicgen4 is off the scale
go with the second one, the SiR II. you wont have to deal with the hastle of rewiring. plus you've got 10 more hp.
definitaly go through hmotorsonline, i just got an engine through them the outside was spotless, i'll have to take off the valve cover and take some pics so everyone will know how good the engines they sell really are. from the smell of the oil it should be perfect, and do remember the oil has probably been in there for like 10 years.
Current: B16A1 SiR-1, w/ ACT Clutch (Street disk w/heavy pressure plate), Short Ram Intake, OBX exhaust w/ high flow cat, Falken Azenis 195/60/14's
Best Quarter Mile R/T.134, 60' 2.278, 330' 6.120, 1/8 9.345 , MPH 76.09, 1000 12.129, 1/4 14.501, MPH 94.76
Turbo Kit: $?
Turbo Status: CRPfab Ramhorn Manifold, Garret T3/T4E Turbo(Brand New), Greddy TypeS, TiAL 38mm Wastegate, DSM 450cc injectors, OBD1 conversion
Current Savings: $400
For Sale: 3" Downpipe w/electric cut-out : $305 shipped
ef9civicgen4 is offline   Reply With Quote
Old 01-21-2004, 04:07 PM   #10
GSRCRXsi's Avatar
you are gonna want the one with the hydro tranny. yes you COULD use the cable tranny but why? you will want the SIR-II changover. hydro tranny, obd1, and with a few mounts this swap is almost plug and play. you will need do run a few wires.
91 CRX si
95 Integra LS
ported ls motor and 5 speed cable tranny electric_rex Parts: For Sale/Trade/Wanted 4 10-10-2006 11:26 PM
*B16 sir2 motor in civic hatch vx 92* ConejoHB HYBRID -> EG-EK / DC 16 11-04-2003 09:43 PM
if you weren't in chat tonight.... pissedoffsol Members' Lounge 33 10-16-2003 12:30 AM
Selling 2001-2003 Civic Lx Motor KrUsHa Parts: For Sale/Trade/Wanted 0 03-26-2003 09:15 PM
