anyone had this problem when swapping
Old 12-21-2002, 05:43 PM   #1
Rep Power: 15 c17r15 is off the scale
the shop that's supposed to finish my swap is pissing me off
they said it'll take one day to finish the wiring, its been 3 weeks. they took apart my wiring harness trying to look for a short, got a new tps sensor and map sensor, smoked my ecu........
after all that,
they can't find out what is wrong with this problem.
i have a b16a2 with a 96 DX wiring harness. They smoked my p28 ecu and now they got an obd1 AND an obd2 b16a ecu.
when the throttle is under 50%, the engine "stutters" but anything higher than 50% the engine runs real smooth. they said the problem is from the obd2-1 clip and now they sent the obd2-1 clip back to the guy i bought it from.
did anyone run into this problem??
thanks
c17r15 is offline   Reply With Quote
Old 12-21-2002, 11:57 PM   #2
Rep Power: 15 HenryOng074 is off the scale
i had the same problem, but after I got my car tuned with a vafc, it ran smooth. what car year car you got? what shop was working on your car?
1989 Honda CRX Si
B16A Turbo
HenryOng074 is offline   Reply With Quote
Old 12-23-2002, 01:00 AM   #3
did they tell you what was wrong with it??
i have a 96 DX, and I'm in ATL, if you know WSP is the shop
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
Can't Find Problem...Everyone needed AJBurks ECU's, Electronics, and Tuning 6 02-25-2005 03:38 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
problem after swapping head erebunicrx General Tech and Maintenance 4 09-14-2004 12:21 AM
Swapping 99gsr Into 00civic Ex Mount Problem mwolf83 HYBRID -> EG-EK / DC 1 06-14-2003 03:09 AM
