auto to manual swap CRAZY?
Old 09-18-2003, 10:05 PM   #1
Rep Power: 0 andrew714 is off the scale
i want to convert my eg to manual. everyone is telling me thats crazy and really expensive and to just buy a new manual eg. i am thinking that since i will be swapping the engine, i will be having to swap tranny as well and if i get a new manual tranny then all i would need is the clutch, shiftlinkage and shifter. what else do i need and what should i do? thanks
andrew714 is offline   Reply With Quote
Old 09-19-2003, 05:50 PM   #2
Rep Power: 18 jeffsciv23 is on a distinguished road
Send a message via AIM to jeffsciv23
it's not that hard if you are already gonna do the swap. just get the pedals, shift linkage, master cylinder, and clutch lines. ther is probably some other things i forgot but i'm tired so if i think of it then i wil post it.
jeffsciv23 is offline   Reply With Quote
Old 09-20-2003, 08:13 PM   #3
it can become a pain in the ass..but just research and get the right components..
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 09-21-2003, 04:56 PM   #4
Rep Power: 13 brianteel is off the scale
i just did one...you will need the pedal assembly with all the lines running from the clutch to the trans. you will also need the linkage that goes under the car. you will also need the manual trans and ECU.
the only thing i can say is to unbolt the steering column and disconnect all the wires to them to get them out of the way. also remove the fuse box.
next using a 12mm socket unbolt and reomove the pedals. there is a pin for the brake pedal and the throttle cable. it took me about 30 minutes to take the parts out and about the same to put them in. for the wiring there is 2 thick wires that go to the auto shifter just attach them so the car will start. you will have to drill holes for the bolts for the shift linkage and a piece metal do bolt in the hole. in the piece of metal cut a 2 1/8" hole in that plate and the shifter will fit through it.
THE PEOPLE WHO ARE CRAZY ARE THE ONES WHO SAY DONT DO IT BECAUSE THEY WOULD NOT!
email me if you need more clarification
brianteel is offline   Reply With Quote
Auto VS Manual ECU reckedracing ECU's, Electronics, and Tuning 6 06-14-2004 06:48 PM
Auto to Manual Conversion brian11to1 Swap Articles 6 02-14-2004 09:59 PM
Auto B swap into EG Niko HYBRID -> EG-EK / DC 21 09-20-2003 03:26 PM
Auto To Manual 94 Civic V-tech frontstreetracer HYBRID -> EG-EK / DC 8 05-19-2003 07:07 PM
