Auto swap anyone?
Old 11-17-2005, 04:50 PM   #1
Rep Power: 9 bigmikerican is off the scale
[img]style_emoticons/<#EMO_DIR#>/dry.gif[/img] alright ive done an b18c1 auto swap into a 93 civic dx auto chassy keeping it all auto the engine and tranny is jdm cuase only japan made gsr in auto now to the question its all in but the stupid mechanic could not get the right mounts and i searched and every custom mount made is for the manual swap not for an auto so does anyone know what mounts woud make the engine sit best in my ride cause its mounted in but he had to mod some of the body in the engine bay and he F'N bent my hood a little so the valve cover wouldnt hit now i dont care about the hood that much cause im gonna put a cf hood on but i wnat the engine to sit better so i have room for bolt on mods later please if anyone ever dealt with an auto swap of a b18c1 into a 92-95 dx let me know what mounts are best [img]style_emoticons/<#EMO_DIR#>/worthy.gif[/img]
bigmikerican is offline   Reply With Quote
Old 11-17-2005, 05:05 PM   #2
Rep Power: 25 SixtySecondAssassin is off the scale
94-01 integra gs, ls, rs auto mounts will work.
are you having problems with all the mounts or just the tranny mount.
.....deagle.....
SixtySecondAssassin is offline   Reply With Quote
Old 11-17-2005, 05:25 PM   #3
dont know which ones are making it mount up wrong i know he did use integra mounts mixed and matched till he got the right ones but its still not sitting right
Old 11-17-2005, 05:37 PM   #4
yea, did he cut anything? the teg mounts will work.
.....deagle.....
Old 11-17-2005, 05:49 PM   #5
he cut some of my fender well so the tranny can fit and he heated and bended the right wall of the engine bay and its still real tight but it looks like its sitting to high and thats why he had to bend the hood a lil so it wouldnt hit the valve cover
Old 11-17-2005, 05:57 PM   #6
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
[img]style_emoticons/<#EMO_DIR#>/wtf3.gif[/img]
NONE of that is necessary to fit a b-series in a civic. your mechanic is a fucktard
Old 11-17-2005, 06:23 PM   #7
yes he is lol but hes a friend of the family so he only charged me 500 to do the swap and some other stuff like fix my window brakes so hes charging me like close to nothing but he doesnt know shit about swaps and now im fuckin running out of money and patience on this swap its been over three weeks
Old 11-18-2005, 01:30 PM   #8
RETIRED
dude, straight up... if you had to bend frame rails and shit to fit it, the motor is NOT in the car right. you either have the wrong mounts, or they arne't seated properly.
the second you drive away, you're going to snap axles left and right.
Old 11-20-2005, 07:08 PM   #9
omg, get pictures.
90 Integra Sedan
B20V 225 / 153
Old 11-21-2005, 11:46 AM   #10
should get the car back wed so ill have pics after thanksgiving up of the hack job [img]style_emoticons/<#EMO_DIR#>/mad.gif[/img]
Old 11-21-2005, 01:30 PM   #11
you should go kill your mechanic.
90 Integra Sedan
B20V 225 / 153
Old 11-22-2005, 06:48 PM   #12
Rep Power: 15 sleepn_accord is off the scale
despite what everyone here is saying, it is concievable that the frame rail and fender well needed to be modified.
I've converted a GSR to automatic and because the auto tranny is about 1 1/2" taller than the 5 speed tranny and about 1" longer some body fabrication was necessary.
When I did the conversion, I had to sledge the bottom of the frame rail in about 2" to fit and had to reposition the mount bracket (the bracket that's welded to the frame rail) about 1 1/2" back towards the firewall. Additionally, I had to modify the upper portion of the frame rail to allow the bracket to sit back about 1/2"
What you should do is bolt up ALL the other mounts and check your clearances.
If your tranny is clearing fine, then you should see how the INTEGRA tranny mount is lining up with the Civic bracket. I'm thinking that you may have to change the bracket. I haven't had a chance to compare a 5spd vs. auto civic brackets.
Call your local honda dealer and see if there are different part numbers for the tranny mount bracket between autos and 5spds. If a difference does exist, you may be able to modify the mount. If the brackets are the same you're going to have to change the bracket to an integra one. It isn't that hard.. just a bitch to form the frame rail right. (It took me about 5 hours with a sledge to get the form accurate).
sleepn_accord is offline   Reply With Quote
Old 11-23-2005, 05:58 PM   #13
Ive converted cars as well. You dont need to fab anything. You can shim the mount to get the necassary height adjustment.
additionally, just recently i got rid fo the shimmed mount for a custom piece made by camp1320.com.
90 Integra Sedan
B20V 225 / 153
Old 11-24-2005, 06:49 PM   #14
Rep Power: 11 1995EGGuy is off the scale
Send a message via AIM to 1995EGGuy
OMG after reading this I feel like my EG's rail is useless. I did a B16 SIR-II swap with auto trans and i couldnt get a mount to fit so i used my D15B7 trans mount and cut some of it to fit in the holes and also curved the rail so the trans could sit in good. BUT! i wanna convert to manual now, what do i have to do so my manual mount would go in?
BTW- what car did the M24A trans come from and what auto mount would of fit if i didnt cut nothing.
1995EGGuy is offline   Reply With Quote
Old 11-28-2005, 08:29 PM   #15
Rep Power: 13 Lshatch916 is off the scale
You need this tranny side mount as I found out the automatic cars used a different mounting point on the car, thus the mount on the tranny is different than the manual version, here it is for $175. i had to get the same mount when i did my auto to manuel swap
http://hasport.com/catalog/product_i...roducts_id=115
93 LS hatch
<span style=\'color:teal\'>T E A L - H A T C H - C L U B member# 001</span>
<span style=\'color:TEAL\'><a href=\'http://www.honda-tech.com/zerothread?id=1234691\' target=\'_blank\'>T E A L - H A T C H - C L U B</a></span>
AHHHH SKEET SKEET SKEET
Lshatch916 is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
