Axle length problem
Old 08-23-2005, 08:08 PM   #1
Rep Power: 0 fmrdodgeman is off the scale
I did a search here as well as talked to everyone who has done this swap and no one has seen this. I need some help here.
I have a 95 Civic Ex with a B18C1 swap. The tranny I believe is out of a 99 or 2000 si. The left side axle fit in ok but the right shaft is probably an inch or 2 short. The trans is a hydraulic unit. As far as I know all B series right axles are the same 94 and up Integra or Civic. The engine alignment is correct and the mounts are B18 civic mounts. Any ideas.
fmrdodgeman is offline   Reply With Quote
Old 08-24-2005, 12:05 AM   #2
Go fast, Go Cheap
Ride:  Hybrid POWER!
Rep Power: 24 jimboburgess will become famous soon enoughjimboburgess will become famous soon enough
Send a message via AIM to jimboburgess Send a message via Yahoo to jimboburgess myspace
Right and left axles are different, you probably know that. one side has a carrier bearig the bolts to the tranny.
Resurrected Sol
http://hondaswap.com/auto-multi-medi...ted-sol-60210/
2003 Civic Hybrid (I'm a grown-up now)
www.myspace.com/burdenelectronica
jimboburgess is offline   Reply With Quote
Old 08-24-2005, 12:46 AM   #3
...Hi...
HatchSpeeD's Avatar
Rep Power: 26 HatchSpeeD is an unknown quantity at this point
Send a message via AIM to HatchSpeeD
Are you using the midshaft?
HatchSpeeD is offline   Reply With Quote
Old 08-24-2005, 03:00 AM   #4
Rep Power: 9 EG_Case is off the scale
alright heres what you do, if the Pass side axles still out look at the back of the hubs and see if it had groves it shouldnt, then look at the axle and see if it has a ring of Groves if it does you have a ABS axle and you need a NON ABS for a 94+ teg , 99-00 Civic, or any B16'ed Delsol i believe 94+
with Gas Prices these days its a good thing i dont eat alot of gas but i Pack Alot of Muscle
EG_Case is offline   Reply With Quote
Old 08-24-2005, 03:12 AM   #5
VTECin5th's Avatar
Rep Power: 41 VTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of light
Send a message via AIM to VTECin5th
werd^
I was gonna say, try ABS axle, or if have ABS axle try non ABS axle?
Good luck.
k20dc5
VTECin5th is offline   Reply With Quote
Old 08-24-2005, 05:25 AM   #6
Rep Power: 14 evoracer03 is off the scale
abs and non abs axles are still the same length, so thats not gonna make a difference. u sure u got the right axle and not one off an older civic or something?
i'm not all fast...... just halfassed!
evoracer03 is offline   Reply With Quote
Old 08-24-2005, 06:00 AM   #7
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
ABS doesn't matter at all. You can try popping the ring off if it is, but I don't think it will make a difference. Possibly an automatic axle.
Also look at the spines on the shaft the goes into the spindles and tranny, on one of the axles this is going to be the full on bothsides, the other is going to have splines only halfway, I forget which one goes in the tranny, but if I remember correctly, the full spline goes in the diff, it's been a while.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 08-24-2005, 12:49 PM   #8
yea maybe auto, i was just sayin that from experiance, i was sold a ABS axle for a 94+ teggy and for some reason it was about an inch or 2 shorter then it should be, i brang it back and got non ABS and they worked perfect...
Old 08-24-2005, 01:13 PM   #9
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Nope, all manual B series axles 94+ are the same length. ABS is just a ring that the sensor reads as pulses.
95 CX|B16A2
Old 08-24-2005, 11:06 PM   #10
Actually I picked up axles from even Advanced Auto parts and Auto zone. Went to summit racing equipment and pulled all possible right axles from their stock. All are absolutely the same. The trans is an s4c. Maybe I'll put it on the frame machine but an inch and a half would seem to be noticeable. I'm a 10 year ASE tech who left the dealer because minivans are boring. I left hot rodding because after working on minivans all day you don't want to work on your hot rod ( which this civic is replacing) Now I remember the other reasons I sold the old dodge -working out the bugs.
Old 08-24-2005, 11:10 PM   #11
Rep Power: 13 confusatron is off the scale
I could be wrong here, but when I got the axles for my swap (B16A2 into EG civic) I not only needed the axles, but this thing called a midshaft or something. It's a piece that bolts to the back of the motor and sits between one of the axles and the transaxle hole in the transmission. That could be your missing couple inches. However, I may be wrong as I don't know anything about B18 swaps. Anyone else know?
1993 Civic DX Hatch B16A SiR-II --SOLD!
1988 Supra Turbo automatic FOR SALE $2000 needs trans repair, power steering repair, a few leaks, Clean Body, Alpine, leather interior in decent shape, JDM motor rebuilt with HKS metal head gasket and ARP head bolts.
1996 Toyota Celica GT (daily driver)
confusatron is offline   Reply With Quote
Old 08-24-2005, 11:20 PM   #12
The passenger side is directly into the carrier so thats not it. This is horribly frusterating as the left side fits fine. Thanks. Ikeep thinking I'm overlooking something stupid but an inch and a half?
Old 08-25-2005, 01:30 AM   #13
like i said maybe its the wrong axle.. it might be for auto like the other guy said
deff got to and auto part store and ask to look at one and see whats wrong from there
Old 08-25-2005, 06:10 PM   #14
Is there the possibility of an s4c coming out of something other than a b series civic delsol or integra?
Old 08-25-2005, 08:19 PM   #15
Does anyone know the difference between a right side LS axle vs the GSR?
Old 08-26-2005, 12:03 AM   #16
theyre the same length.... that wouldnt make a difference. if its short then you have the wrong axle, theres no other way around it.
Old 08-26-2005, 01:36 AM   #17
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Originally posted by fmrdodgeman+Aug 25 2005, 11:10 PM--><div class='quotetop'>QUOTE(fmrdodgeman @ Aug 25 2005, 11:10 PM)</div><div class='quotemain'>Is there the possibility of an s4c coming out of something other than a b series civic delsol or integra?
[/b]
Could have come from a 99-00 Si, but it would still not make a difference.
None
<!--QuoteBegin-evoracer03
@Aug 26 2005, 05:03 AM
[/quote]
Correct
95 CX|B16A2
Old 08-27-2005, 03:03 AM   #18
The company I bought my axles from said that they can be used in ANY B-series swap.
"Perfect for any B-Series engine swap into a Civic or Integra with hydraulic transmission. B16A, B16B, B18B, B18C1, B18C5, etc..."
Mine is a B16A2 swap and it required the midshaft. The axles fit perfectly with the midshaft.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...AMEWA%3AIT&rd=1
Of course, it may be the fact that you're using a trans for a motor other than the B18C1 motor. Can you get rid of that trans and get the correct trans for that motor?
Old 08-27-2005, 03:56 AM   #19
are you actually suggesting that he toss his tranny for a new one because of a short axle??? man, thats like doin an engine swap cuz your fuel line leaks!! heres the deal....
no matter which engine or trans youre using, if its b-series and the left axle fits, then that means that the engine/tranny combo is in the correct position. period. now heres the sure fire way to determine your issue: measure the length of the driver side axle, the passenger side axle should be within 3/4", depending on how compressed the cv is. and before everybody goes telling me the passenger side is longer, let me just say that the axle itself is not any longer, only the splines so that the proper axle will line up on the correct side for the operation of the diff. if the axle is shorter than the driver side but the spline count is correct, odds are you got a 4th gen axle.
Old 08-27-2005, 06:57 AM   #20
listen to this man.. Btw almost forgot to ask does it fit all the way into the tranny?? becuz when i ran into the problem it was a 4th gen axle it went in about half n inch then just wouldnt.. not even sure the teeth lined up
Old 08-27-2005, 07:10 AM   #21
theyll still fit, thats why we can run 90-93 teg axles in our hydro trannies without an issue. the only time ive had them stick like that is when the snap ring gets bent out a lil bit, then it gets hung up on the splines
Old 08-28-2005, 01:22 AM   #22
No, what I was suggesting is that maybe he's having this problem because he's got the wrong transmission for the swap. When you buy the swap package, usually unless you already got a b-series trans in the thing, you buy the motor and trans together. He bought a trans from a different car than his motor is from. I'm suggesting that maybe the reason he's having this problem is because of that. Again, I'm no expert, but it sounds reasonable to me.
Old 08-28-2005, 03:50 PM   #23
Originally posted by confusatron+Aug 28 2005, 05:22 AM--><div class='quotetop'>QUOTE(confusatron @ Aug 28 2005, 05:22 AM)</div><div class='quotemain'><!--QuoteBegin-evoracer03@Aug 27 2005, 02:56 AM
[/b][/quote]
okay, i cant take this any more, the biggest problem with forum boards is that whenever
something sounds "reasonable" to somebody they throw it out there for someone else to try. my understanding of asking a question here is to talk to someone who either knows the answer, or someone having the same issue, not the guy who wants to toss a wild guess ot there and see what happens. if you dont have any facts to back it up, please dont suggest it so someone else can waste their time, money or car.
okay, now back to the topic. no matter what car the tranny came out of, the obvious fact is that its b- series. now, couple that with the fact that all 94-00 b-series axles are the same length, along with 90-93 but have a different intermediate shaft, and you have your answer: its the wrong axle. cant be b-series axle because the left one fits properly which means the motor is placed correctly. measure the pass. side axle from right where it would meet up at the back of the hub to where it meets the oil seal on the tranny, dont measure the splines. now do the same with drivers side. youll see the difference.
Old 08-31-2005, 01:59 AM   #24
so did you ever get your axle problem solved dude?
