axles
Old 11-06-2005, 07:33 PM   #1
Rep Power: 14 Tyler is an unknown quantity at this point
I went to order axles for my b16 tranny so I ordered del sol vtec axles, but the drivers side needs a male inside end, which these axles have a female, I searched around and found that 90-93 integra axles are male on the inside end, will these axles work? need help asap need to get my car going, Thanks.
1992 gsr hatch
2004 RM250z all black
Tyler is offline   Reply With Quote
Old 11-06-2005, 08:21 PM   #2
Rep Power: 15 DelSlo is off the scale
<div class='quotetop'>QUOTE(Tyler @ Nov 6 2005, 07:33 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
not exactly sure what you are trying to say but just get integra axles or yeah, del sol DOHC v tec, cause the 93 v tec axles are gonna be a d series. or axles out of a 99-00 Si. anything with a b series engine in it. just get em!
93' Del Sol
2000 B16A2 swap.
garrett T3/T4 (.48/.60)
Weapons of choice.. Innovate LC1 and Crome Pro
Faze EL Engine management guages.
DelSlo is offline   Reply With Quote
Old 11-06-2005, 09:34 PM   #3
Rep Power: 29 VTECPOWER is off the scale
Send a message via AIM to VTECPOWER
If this is a cable trans in a ef, then u need 90 integra non abs axles.
If not, we need more info.
DB8 450whp project......
VTECPOWER is offline   Reply With Quote
Old 11-06-2005, 09:49 PM   #4
eg hatch hydro.
1992 gsr hatch
Old 11-06-2005, 10:05 PM   #5
Either 95 del sol dohc vtec axles.
Or 94+ integra axles i do believe.
Old 11-06-2005, 10:08 PM   #6
what I'm sayin is i ordered the del sol b16 axles, got them in the passenger was fine, the driverside has a female inside end and my intermediate shaft has a female end get it? It needs to have a male inside end it didn't I need to know which axle I need to order.
1992 gsr hatch
Old 11-07-2005, 05:13 PM   #7
Scorchin Civic's Avatar
Rep Power: 12 Scorchin Civic is an unknown quantity at this point
Send a message via AIM to Scorchin Civic
I am using all 90-93 Integra axles in my 92 Civic with a B20 & B16 tranny. I think he is talking about the mid shaft. I know that they are different between the 90-93 and the 94 and up. The 90-93 Integra mid shaft has the female end while the 94 and up has the male end. What ever year of axle you go with you will also have to use the same year mid shaft too.
Integra & Civic Swap Parts For Sale! My E-Bay
My MySpace
Scorchin Civic is offline   Reply With Quote
Old 11-07-2005, 05:21 PM   #8
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Like scorchin said, you need the drivers side axle with a male end, these are found in the older cable tranny B16As and the 90-93 Integras.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 11-07-2005, 05:29 PM   #9
Also, just to let you know. What ever year set of axles you decide to go with make sure you have the same year tranny seals. I don't know what you call them but there the round rubber seals that sit in the tranny where the axles go into. Because if you use the 90-93 axles then you will smash that seal (since I am guessing your tranny is a hydro 94 and up) and have a leak or the axle will pop out. Long story short, make sure everything is with in the same generation. All 90-93 or all 94 and up.
My MySpace
