B-swap mount question
Members have access to more features and see fewer ads! It's free, what are you waiting for?
Old 01-15-2008, 09:20 PM   #1
Rep Power: 0 fronomo is on a distinguished road
Default B-swap mount question
Ok, I currently have a d16y8 in my EJ8 and have some pretty nice innovative mounts. I am building an ls/vtec to swap into my car and have seen different things, some saying that the d-series mounts (or some of them) can be used for a b-series swap as well. Others tell me this isn't true. I figure this is a good place to ask. Can any of the d-series mounts be used in my swap?
fronomo is offline   Reply With Quote
Old 02-03-2008, 08:22 PM   #2
Rep Power: 0 PhrequenC is on a distinguished road
im in the same boat bro. what mounts do i need exactly for my swap? lsvtec b18b into ej8 99-00
PhrequenC is offline   Reply With Quote
Old 02-03-2008, 10:44 PM   #3
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 98 BrutalB83 has a brilliant future
BrutalB83 has a brilliant futureBrutalB83 has a brilliant future
You guys should check out the reference section:
6th gen Civic Basic swap overview
Apparently you need the rear transmission mount from a 99-00 Si or a 94-01 Integra, and the driver's side mount from the 99-00 Si. If you want to keep your A/C, then you'll also need the A/C bracket from a Del Sol VTEC. Everything else you can reuse.
If you find anything I say helpful, please leave me some rep...
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
Please DO NOT PM me with tech questions! Ask your questions on the forum so we can all benefit from the answers...
BrutalB83 is online now   Reply With Quote
Old 02-03-2008, 10:53 PM   #4
Rep Power: 14 killercannible will become famous soon enough
You cannot use integra rear or drivers side mounts in 96-00 civics. Tranny mount will work fine. If you have innovative mounts then you can use a 94-01 integra drivers side mount i beleive. I have that mount and it basically converts the civic mount to the integra and eg civic design.
Got my swap!!! Needs to be faster.
killercannible is offline   Reply With Quote
Old 02-08-2008, 10:16 AM   #5
will fist you!
UNDR8D's Avatar
Rep Power: 38 UNDR8D has much to be proud ofUNDR8D has much to be proud ofUNDR8D has much to be proud ofUNDR8D has much to be proud ofUNDR8D has much to be proud ofUNDR8D has much to be proud ofUNDR8D has much to be proud ofUNDR8D has much to be proud of
Yah, the EG and and the DC share the same chassis dimensions. The integra rear mount will not work in a 96-00. I recently ordered the rear mount from a 99 si to use in my EJ2 and it was far too short at the top. I had to order the DC2 rear mount.
UNDR8D is offline   Reply With Quote
Old 02-09-2008, 02:59 PM   #6
boostedek9's Avatar
Rep Power: 5 boostedek9 is off the scale
just use ll the mount from a 99-00 civic si. thats what i used in my 96 EK hatch and it bolted up smoothly with no issues and yes you can use the 94-01 integra rear t bracket
I didnt get a turbo to go fast....You see I just got one cause it makes my girl HOT!!!!
boostedek9 is offline   Reply With Quote
Old 02-09-2008, 04:41 PM   #7
You cannot, I must stress cannot, use the integra rear mount in a 96-00 civic.
Old 02-10-2008, 12:34 PM   #8
boostedek9's Avatar
sorry i was mistaken you cannot use the integra rear t bracket just like killercannible said
Old 02-10-2008, 06:13 PM   #9
Rep Power: 0 qtmac_mien has a little shameless behaviour in the past
Send a message via AIM to qtmac_mien
99-00 SI rear L bracket
99-00 SI timing belt side motor mount bracket(bolts to the block with 2 studs sticking up)
AIM: shrtxqtxmienxboi
email: qtmac_mien@hotmail.com
qtmac_mien is offline   Reply With Quote
Forum Jump
Engine Swap Question RMMfan Civic and del Sol - EG and EK 17 10-28-2006 10:36 PM
H22A integra swap Transmission question. rawerz HYBRID -> ED-EF / DA 6 10-16-2006 01:05 AM
B20 swap question mylasthatch HYBRID -> EG-EK / DC 4 09-12-2006 03:46 AM
Del Sol S D15B7 to D16y8 swap question oakley2002@cox.net HYBRID -> EG-EK / DC 1 01-21-2004 12:32 PM
Y8 Head Swap Question. Need Help. All Show HYBRID -> EG-EK / DC 3 08-20-2003 03:09 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
