b16 in 97ex = problem after problem
Closed Thread
Old 08-22-2004, 02:00 PM   #1
Rep Power: 0 terribl3jon is off the scale
have had like every problem you can have with this swap.. but now my spark plugs are fouled and they are covered in gas and i think even oil! i changed the plugs and tried to start the car and it still wont turn over! I HATE THIS CAR
pleeeeassee someone help me out
terribl3jon is offline
Old 08-24-2004, 08:22 AM   #2
Rep Power: 16 mrnice1058 is off the scale
Send a message via AIM to mrnice1058
ok sounds like your engine is out of timing badly, take off your valve cover and turn your crank until your cam gears are both pointing up, you will see the two arrows once you do that make sure your crank is pointing to the fourth dot on the crank is lined up with the top dead center mark if not you need to put them at tdc make sure you didn't bend a valve or messed anything up, if your car is cranking but not turning over it is down to timing let me know if it works
started but running pretty rought have any advise pm me and let me know!!
mrnice1058 is offline
Old 03-22-2009, 09:53 PM   #3
Neighborhood Lush
BlackFrog's Avatar
Rep Power: 23 BlackFrog has a spectacular aura aboutBlackFrog has a spectacular aura aboutBlackFrog has a spectacular aura about
Send a message via AIM to BlackFrog
turning over = cranking. is the engine cranking but not firing, or its not cranking over period?
EG2
Drink Beer.
BlackFrog is offline
Old 03-23-2009, 03:42 PM   #4
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
5 years old, I'm sure he has the problem fixed or the car is gone by now.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline
Closed Thread
