B16 Auto Swap Question
Old 06-24-2006, 11:44 PM   #1
Rep Power: 11 1995EGGuy is off the scale
Send a message via AIM to 1995EGGuy
Default B16 Auto Swap Question
I'm about to buy a B16 full auto swap and it comes with every single mount but i'm worried about the top transmission mount will it bolt right in from the chassis to the transmission with no problems? I'm putting B16A Sir-II into a 95 civic 4 dr.
1995EGGuy is offline   Reply With Quote
Old 06-27-2006, 09:50 PM   #2
Nobody knows?
Old 06-27-2006, 11:11 PM   #3
Rep Power: 0 jeyson is an unknown quantity at this point
you have to use the mounts of a gsr or single cam motor all three of them
jeyson is offline   Reply With Quote
Old 07-25-2006, 03:55 PM   #4
Anybody else know? im currently using a single cam non vtec auto mount which i had to cut to fit but i want to use the right mount.
Old 08-09-2006, 08:45 PM   #5
Rep Power: 0 masqjode is an unknown quantity at this point
everything looks fine swapping a b16a into a 5g civic(92 to 95) but there's a dif in the automatic and a manual chassis i saw an article that the guys cut the motor mount location and welded a little foward ,or you just can make your life a little simply and get the special motor mount for automatic chassis(yes they have it at hasport) for around $175 and just bolt in
masqjode is offline   Reply With Quote
Old 08-09-2006, 10:40 PM   #6
can you send me the link?
Old 08-10-2006, 01:12 PM   #7
Would the Integra LS auto trans mount work also?
Old 08-12-2006, 05:48 PM   #8
Rep Power: 7 johnee is on a distinguished road
Exclamation
The stock civic mounts work fine..You have to knock in the chassis wall about an inch on the transmission side..And you need to modify tranny mounting bracket, by shaving it down a little and drilling new mounting holes for the tranny mount to bolt up..Im posting this from experiance because I just had this swap done last week..And believe it or not this auto/swap really moves..
johnee is offline   Reply With Quote
Old 08-13-2006, 11:35 PM   #9
sure it' hasport.com
Old 03-15-2009, 03:26 AM   #10
Greenhorn
Rep Power: 0 epmex is on a distinguished road
ima get the same thing pretty soon and pu it on an ek chasi.... keep you guys imformed....
how is it working out for you???
sow it has b16a has 170 hp?
epmex is offline   Reply With Quote
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
b16 sir2 swap old Skuul Hatch HYBRID -> EG-EK / DC 8 11-25-2004 11:24 PM
b16 swap in a 97 civic mrnice1058 HYBRID -> EG-EK / DC 3 11-22-2004 11:22 PM
wtb: B18A or B16 auto tranny, NYC local pickup ew915 Parts: For Sale/Trade/Wanted 1 09-01-2004 07:14 PM
B16 swap question allmotord16rex HYBRID -> ED-EF / DA 3 07-10-2003 07:40 PM
