b16 error code 14
Old 10-28-2009, 01:22 AM   #1
Greenhorn
Rep Power: 0 justgohonda is on a distinguished road
Default b16 error code 14
cant clear code 14 on my b16a2 swap it is in my 1996 cx hatch pls help i need some troubleshooting help. i swapped out the iacv no go
justgohonda is offline   Reply With Quote
Old 10-29-2009, 06:48 PM   #2
tabKola's Avatar
Ride:  civic ek 4 door
Rep Power: 5 tabKola is on a distinguished road
What engine harness are you currently using and what ECU?
tabKola is offline   Reply With Quote
Old 11-06-2009, 11:43 AM   #3
Rep Power: 0 88crx1589 is off the scale
I have an ef with a b16 obd0 swap and i have done the same thing with the code still there. I have no idea y and I'm having trouble finding anyone who has also had this problem.
88crx1589 is offline   Reply With Quote
Old 11-06-2009, 11:46 AM   #4
AHHVTEC's Avatar
have you checked to see if the iac is bad
Old 11-06-2009, 11:59 AM   #5
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Make sure you have the right connector hooked up to it. There are three plugs in that area that can be plugged into the wrong things. Check the wire colors against what should be there.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 11-06-2009, 12:01 PM   #6
AHHVTEC's Avatar
troof ^^ happens alot
Error code 1 & 23 darien234 HYBRID -> ED-EF / DA 6 12-07-2004 02:08 PM
error code ^crx^ HYBRID -> ED-EF / DA 4 08-08-2004 07:59 AM
getting error code 43 Danabis General Tech and Maintenance 1 02-20-2004 12:20 AM
ecu error code 21 pwrfulz28 ECU's, Electronics, and Tuning 11 12-05-2003 03:29 PM
Error Code #9: CYP Why? D See 2 ECU's, Electronics, and Tuning 0 08-12-2003 11:19 PM
