B16 Problems
Old 04-16-2003, 01:53 AM   #1
Rep Power: 0 Vtec_si is off the scale
Hi, Ive just put a b16a1 into an 89 rex si and im having idling problems and when under a light load the engine runs poorly;however, when given more than approx. 25% throttle, it clears up a little but still lags a lot of power. Any information would be greatly appreciated.
Thanx,
Craig
Vtec_si is offline   Reply With Quote
Old 04-16-2003, 08:31 AM   #2
Rep Power: 15 sooboss is an unknown quantity at this point
does it run okay when its warmed up is it on. a cold start up that it bogs. or does it run like that even after warmed up.. check your spark plug wires are they okay and not arcing. are they in the right firing order. are all sensors hooked up? Check for vaccum leaks if you did some vaccum line plumbing.
1991 Civic HB B16a swap
1992 Civic HB B18C swap Waiting
sooboss is offline   Reply With Quote
Old 04-16-2003, 05:22 PM   #3
Rep Power: 14 pootSIracer is off the scale
Send a message via AIM to pootSIracer Send a message via MSN to pootSIracer
make sure you spark plugs are tight tat what was wrong with mine
if you live your life 1/4 mile at a time you watched that stupid movie to much put away mommys car and show some talent
pootSIracer is offline   Reply With Quote
TONS of parts for sale B16, GSR, Type R Envy_Motorsports Parts: For Sale/Trade/Wanted 25 10-16-2008 01:08 AM
Crx b16 problems b18c1civic97 HYBRID -> ED-EF / DA 19 05-07-2007 02:53 PM
jdm b16 with p72 ecu vtec problems junhonda20 ECU's, Electronics, and Tuning 9 07-22-2004 03:52 AM
Vaccum Problems On B16 90integb16a HYBRID -> ED-EF / DA 1 05-08-2003 12:43 PM
B16 Ecu Redline Problems possessed imports Engine Building 0 03-08-2003 08:45 PM
