B16 SiR II into a 92 Civic Dx Hatch question (Wiring VTEC?)
Old 02-22-2007, 12:03 AM   #1
Location: Maine- Where it's cold as a bitch year round.
Ride:  92 Honda Civic
Rep Power: 9 bd122789 is off the scale
Send a message via AIM to bd122789
Default B16 SiR II into a 92 Civic Dx Hatch question (Wiring VTEC?)
I have a 1992 Honda Civic Dx Hatch. It has a sohc non-vtec engine. I just recently bought a B16 SiR II and I am unsure on how to run the vtec to the car since my car did not originally have vtec. Do I need to run something to the ecu? Do I need to run a wire somewhere else? Please help, thanks.
Unlike my girl, I like Honda's with B's instead of D's.
bd122789 is offline   Reply With Quote
Old 02-22-2007, 01:24 AM   #2
Ride:  92 Civic Hatch
Rep Power: 7 random_hero is on a distinguished road
Here's some information about wiring that you might find helpful. You can use the DX harness. Only '92 civics (no matter what trim level) came from the factory wired for VTEC. The VTEC wiring only runs from the ECU to the cannon plugs on you passenger side shock tower. The engine harness side of that cannon plug does not have VTEC wires on it, because there is no VTEC solenoid on the DX engine. All you will have to do for wiring is add the wires from the VTEC solenoid and pressure switch into the cannon plug if you would like that factory look. You can get the pins at your local Honda dealer for free. Attatch the wires to the pins and push the pins into the cannon plug, then reconnect the cannon plug and viola you have VTEC. When it comes to the knock sensor, just go straight to the ECU. I have a '92 DX hatch with a '95 SiR II engine in it, and I used my DX harness. If you can get your hands on a '95 SiR II engine, it will be even more simple. The '95 SiR II engine only needs one wire for the VTEC solenoid, and one wire for the knock solenoid. The VTEC pressure switch wire was eliminated in '95. Here's another place to go for pinout information and wiring, .: FF-SQUAD.COM [v.2] :. and click on the info net link. Hope that helps!
Quick! Don't just do something, stand there!
random_hero is offline   Reply With Quote
Old 02-22-2007, 04:31 PM   #3
Thanks that is a lot of help, but I do have two more questions. Where would you wire the knock sensor into the ECU? Also will the existing exhaust of the car hook up with the new engine directly?
Old 02-22-2007, 04:32 PM   #4
Thanks that was a lot of help, but I do have one more question. Where would you wire the knock sensor into the ECU?
Old 02-23-2007, 01:55 AM   #5
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
ECU Pinouts
D3 for the knock, I can't remember if the DX has the cat right off the manifold, or at the bottom. if it's at the bottom (end of the header) than it should bolt up, but will be a bottleneck. If it is like the VX and right off the manifold before the down section, than no, it won't bolt up.
Old 02-23-2007, 03:16 PM   #6
skillz2k5's Avatar
Rep Power: 14 skillz2k5 is off the scale
There is also a very detailed write up on this lurking some where in the depths of hondaswap. I'd post a link but I'm lazy and apparently so is your ability to search
EDIT: I'm having a bad day maybe this will help with yours
How to wire vtec
skillz2k5 is offline   Reply With Quote
Old 02-23-2007, 03:23 PM   #7
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
i thought all 92's were wired for vtec already
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 02-23-2007, 07:27 PM   #8
they are
b16a obd 0 tune up parts list feet_ HYBRID -> ED-EF / DA 6 12-27-2007 08:50 PM
1989 Civic hatch seat interchang question hada88crxsi Civic and CRX - EF 3 01-06-2007 02:38 PM
wtb: 99-00 obd2b civic si wiring harness dohc vtec g24jr Parts: For Sale/Trade/Wanted 2 05-10-2005 02:45 PM
Part Numbers for 89Si/B16 OBD0 Swap steelbuster Swap Articles 0 11-16-2003 07:36 PM
