B16 sirII into 92 cx civic hb
Old 10-16-2003, 09:26 PM   #1
Rep Power: 14 Gooseguir is off the scale
I plan to order a b16 with ecu and tranny from hmotorsonline tomorrow. I already have the motor mounts, shift linkage, and axles. I wanted to know exactly what the wiring entails, what I need to do to the engine harness and such. Also any tips from anyone who's done this swap before, like what to expect. Thank you much, any help would be appreciated. 92 cx civic hatchback
Gooseguir is offline   Reply With Quote
Old 10-16-2003, 10:50 PM   #2
Rep Power: 16 darwins_vtech is off the scale
Send a message via Yahoo to darwins_vtech
all right, you will need to run wires, or get a new wiring harness like an ex. THe wires will be for vtec, and then a knock sensor wire no matter what. the shift linkage will be a bitch to get apart on the motor that is in your car. When you go to get your axels off, you will need an impact wrench with atleast 400lbs of torgh, if you have air conditioning you will need to get a bracket from a del sol B16. and get a bigger radiator, the stock won't be big enough most of the time. A delsol dual core works great. (get a genaric one from radiatorbarn.com) new hoses for the radiator no matter what. and then you will most likely need to get a new tps because they are broke on almost any swap. Good luck,
Darin
darwins_vtech is offline   Reply With Quote
Old 10-18-2003, 02:54 PM   #3
Ninja Member
Cashizslick's Avatar
Rep Power: 117 Cashizslick has a reputation beyond repute
Cashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond repute
Not to alarm you, but have fun wiring that thing in - Most people say (especially steve from HMO) that the swap will plug right in, but that wasnt the case when i did it - almost everything had to be lengthened or extended - cause the motor was originally in an RHD car.
Good luck with the swap, if you have any questions, feel free to pm me.
Originally Posted by Canadian Finance Minister Jim Flaherty
the recent public policy of privatizing profits and socializing losses is unacceptable to taxpayers
Cashizslick is offline   Reply With Quote
Old 10-21-2003, 08:31 PM   #4
So does that mean I can use the stock engine harness on my old engine or not??
Old 10-21-2003, 08:52 PM   #5
Rep Power: 14 95sir is off the scale
yes, but you will have to add the need wires for vtech and such
95sir is offline   Reply With Quote
Old 10-21-2003, 08:54 PM   #6
What do you need an impact wrench for? It wasnt needed when I yanked mine
Old 10-21-2003, 11:36 PM   #7
Rep Power: 16 sleepercivic is an unknown quantity at this point
Wiring for 92 hatch with JDM b16a
92's are supposed to be pre wired for vtec, at least from ecu to shock tower,
you will also have to add a knock sensor from the sensor all the way to the ecu, run it through the shock tower harness if you want to do it right,
The only thing that you need to find out is what you need to due to o2 sensor, I did the same swap into an EX so I already had a 4 wire o2 sensor , but I am not sure what the cx has.
**Also you will be using your cx wire harness ***
Because of this you will need to make your o2 wires longer because the will not reach around the B16, you can aviod having to splice the wires if you seperate them from the rest of the harness, then you can just relocate them,without cutting the wires.
All of your stock harness will plug into the B16, and you will have one extra plug for the evap purge valve, which a JDM B16, doesn't have
good luck, and take yor time so it will come out good the first time
10/12/07--94 ex for Sale Black/Black pm for details/ Honda-tech.com egsleepercivic
sleepercivic is offline   Reply With Quote
Old 10-22-2003, 01:10 AM   #8
thanks so much for that last post it's by far the most constuctive one I've recieved, that helped me a lot
Old 10-22-2003, 02:30 AM   #9
dohch22a4's Avatar
Rep Power: 31 dohch22a4 is off the scale
Send a message via AIM to dohch22a4
Cashizslick is right. I got a JDM B18C and the harness had to be extended about 28 inches across the engine bay. My buddy Zac sat there for eight hours in my grage and wired a harness extension from scratch out of another OBD I harness that was extra. If you don't want to deal with that headache, I'm pretty sure someone makes them, either Hasport or someone with halfway decent wiring experience. Good luck, mang! Don't forget to spend the extra $300 for LSD. It's worth every penny!
"Conventional wisdom would have one believe that it is insane to resist this, the mightiest of empires... but what history really shows is that today's empire is tomorrow's ashes, that nothing lasts forever, and that to not resist is to acquiesce in your own oppression. The greatest form of sanity that anyone can exercise is to resist that force that is trying to repress, oppress and fight the human spirit."
-Mumia Abu-Jamal
dohch22a4 is offline   Reply With Quote
Old 10-22-2003, 02:59 AM   #10
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
No, he is a fucktard. You can use your USDM harness, and run a couple of extra wires, if it is a 92, it is even easier.
Gooseguir, refer to Sleepercivic's post about the swap, other than your CX having a one wire o2, which can be repinned at the canon plug, it's cake. If you need a link on the repinning, I can find one for you with pics and all.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 10-22-2003, 08:14 PM   #11
That would be bad ass, thanks for all your help everybody. Engine comes tomorrow!
Old 10-24-2003, 09:39 AM   #12
Rep Power: 13 pork1463 is off the scale
I bought the same thing you did from h motors. the 4 wire o2 is a bitch and still is, mine still is not workin'. but that and the v tech is the only thing i had to wire up. Also the radiator hoses for the b16 are 1/8" bigger so you will need an integra or del sol si radiator.
pork1463 is offline   Reply With Quote
Old 10-24-2003, 09:46 AM   #13
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
B18C1 into VX, using VX harness. It's for a GSR, but with a little specific insight, you can use it for a B16 also.
95 CX|B16A2
Old 10-27-2003, 04:28 PM   #14
Ninja Member
Thanks
I know my own experience and i went through wiring hell with my swap.
b16 into 4 dr civic dx b16dx4dr HYBRID -> ED-EF / DA 2 05-19-2004 03:04 PM
Decoding VIN Numbers pissedoffsol General Tech Articles 0 01-11-2004 08:48 PM
98 civic dx to b16 swap cruise_96 HYBRID -> EG-EK / DC 2 12-06-2003 02:11 AM
90 Civic Dx B16 Swap OldSchoolSwap HYBRID -> EG-EK / DC 6 03-13-2003 10:52 AM
Civic 91 Dx With A B16 Sir-ii bossman032 HYBRID -> EG-EK / DC 12 01-15-2003 03:20 PM
