| | LinkBack | Thread Tools |
| | #1 |
| Senior Member | It appears that the throtlle cable on my d-series will not fit with the brackets on the B-series. The length between the bracket and the throttle bellcrank are substantially different. I think I can make a bracket to make it work. Just wondering if anyone else has had this problem. |
| | #2 |
| Member | Reply I did and made a bracket and it worked fine. Someone gave me a bracket a couple weeks ago that fit, but we were unsure what it came from maybe one of the other guys can help on that. But making a bracket works. |
| | #7 |
| Super Moderator Join Date: Sep 2002 Location: New Albany, OH
iTrader: 0 / 0% Ride: 01 is300, 05 s2000, 03 rx300
Rep Power: 58 | agreed. b series throttle cable, do you have a close up pic of your fuel rail by chance? sometimes there is another concern with the fuel pressure regulator and the IAT sensor both wanting to be over the same cyliner, 3 if i remember correctly. do you have the correct shift linkage? |
