Does anybody know what correct mount I have to use for the top trans mount for a B16 SIR-II with a M24A auto trans? (Most likely a B series)
If anybody knows honda part numbers that would help too [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] |
Admin with a big stick
Ride: 2003 S2000
Have you tried the OEM mount? The chassis mount positions are different between the automatic and manual Civics, and they might correspond to the mounts on the auto B transmissions too if you use the OEM mount. I've never tried it, but you could give it a shot.
#7 |
Ride: 2003 S2000
The transmission side mount might be the same, but the chassis mount is different.
#8 |
<div class='quotetop'>QUOTE(1995EGGuy @ Apr 16 2006, 09:58 AM) Quoted post</div><div class='quotemain'>
Does anybody know what correct mount I have to use for the top trans mount for a B16 SIR-II with a M24A auto trans? (Most likely a B series) If anybody knows honda part numbers that would help too [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] [/b][/quote] I have the same set-up b16 sirII coupled to a m24a auto tranny and all we did was tap new holes in the existing upper tranny mount. It seems to work fine although it could look better. |
#9 |
Ride: 93 del Sol Gas sipper
if your chassis is an automatic chassis (which I assume it is since your swapping another automatic in there) although I don't have much (ok any) experiance with automatic b-series, your going to need the mounts from an automatic integra. This is because if your doing an auto->standard conversion, you need the same aftermarket mount weather your doing this in a civic or in an integra.
Collin Material Science and Engineering Michigan Technological University |
