ok, well i've been debating on whether to go with a b16 or a zc. but im leaning towards the b16, so now my question is what year of the car should the b16 come from? because i am totally confused about all this obd0, obd1, obd2 and so on...for a very easy swap in regards with the wiring what year should the motor be and from what car should it come from? but if i go with the zc do i just get the engine and use my si tranny thats already in the car?? and do i use the same ecu?? if anyone can clear this up for me it would be great.
well, a ZC and a b16a ( that u want) came from the same year CRX. the ZC is from the japanese Si and the b16a is from the japanese siR, i believe 90-91 or something?
ZC= Dseries cheap,non-vtec, bolts up to stock tranny and everything for wiring B16a = b series Vtec, need mounts wiring linkage axels ECU, alot more $$ __________________
Sleepers Are the Only way to Go. 1990 CRX Si B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs & Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears. 1/4 = 14.73 60' = 2.48 trap = 95.03mph Soon to get: Header, Slicks Future 13 second all motor LS! |
B happy
Ride: dohc 95 egg
Add mounts to any DOHC swap zc or B whatever,for the same reason the hood won't close because of the extra lenght at the cam pully side,or you can cut the ribs underneath.Yes a zc is going to be cheaper,but not easier.All the parts needed to fit the B in that car are easily had through aftermarket and it isn't like buying another motor or something.Plus you'll be much happier with the B.I have the pleasure of living in a country that has both,I've driven them back to back and the vti (B16A) is worth the extra.
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 25 | 10-16-2008 01:08 AM |
| B16 to STD help needed | ef_hatch | HYBRID -> ED-EF / DA | 20 | 04-14-2004 11:52 AM |
| B16 into 90 Integ | EFB18A1 | HYBRID -> ED-EF / DA | 10 | 02-19-2004 02:19 PM |
| Distributor for b16 NEEDED | CRXproject | Parts: For Sale/Trade/Wanted | 3 | 10-16-2003 10:57 PM |
| Hybrid jdm b16 tranny | crxfreak | HYBRID -> ED-EF / DA | 2 | 06-30-2003 09:55 PM |
