b16a engine mounts ? avid - hasport ?
Old 08-07-2006, 06:37 PM   #1
Rep Power: 7 loverboy is on a distinguished road
Default b16a engine mounts ? avid - hasport ?
Hi !
I need engine mounts for my ek 96 coupe into b16b or a.
I saw hasport and avid racing mounts, which is better ? the avid set comes with 5 mounts (tranny too) ?
Is there standart mounts for the swap like the si 99 mounts that can fit ?
Thanks !
loverboy is offline   Reply With Quote
Old 08-08-2006, 04:52 AM   #2
Rep Power: 7 EJ6 b18c1 is on a distinguished road
go hasport.. yes the si mounts..
EJ6 b18c1 is offline   Reply With Quote
Old 08-08-2006, 04:19 PM   #3
Why the hasport is prefeable then the original si mounts ??
I believe the si used mounts cost much less then hasport (300-550 $ 2 ekstk)
Old 08-09-2006, 12:40 AM   #4
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
The HASport mounts will be made from billet aluminum and be lighter and stronger than the OEM Si mounts, plus they will have polyurethane inserts instead of the OEM flimsy rubber. If you want to use the Si mounts, it's still a very good path to take, and it's MUCH cheaper.
zc swap into 85 crx? devnjeff HYBRID -> ED-EF / DA 4 07-10-2005 11:09 PM
FS: JDM H22A engine, tran, ecu, HCP H22-EG mounts Shongku Parts: For Sale/Trade/Wanted 7 11-04-2004 04:52 PM
B16A Variants pissedoffsol Swap Articles 0 01-12-2004 02:31 AM
HaSport Motor Mounts 88-91 CRX/Civic *Cheap* AllmotorCRX161 Parts: For Sale/Trade/Wanted 1 11-13-2003 01:00 PM
What is double clutching? Calesta General Tech Articles 0 12-27-2002 03:06 PM
