Facebook Twitter
B16a into ej9 rev problem :(
This is a discussion on B16a into ej9 rev problem :( in the HYBRID -> EG-EK / DC forum
Ok so I have been doing a b16a swap into my ej9 and I have almost finished but when I took it for a test drive I noticed revving from stand still to top 8k ish takes age and is really slow and I have ...
Old 02-03-2012, 02:42 PM   #1
Default B16a into ej9 rev problem :(
Ok so I have been doing a b16a swap into my ej9 and I have almost finished but when I took it for a test drive I noticed revving from stand still to top 8k ish takes age and is really slow and I have hunting revs quite low rev range and I am unable to find a vacuum and hose diagram that relates to this swap I'm soo stuck can anyone help?
Zachy2245 is offline   Reply With Quote
Old 02-04-2012, 02:09 PM   #2
Anyone?
Old 02-04-2012, 11:11 PM   #3
How does it sound when vtec kicks in? Have you checked fuel pressure?
raabdunn is offline   Reply With Quote
Old 02-06-2012, 06:42 PM   #4
Is this a JDM B16a or a USDM? I bought a jdm motor and had the same issue. After hours of checking every thing and found I had 2 plugs in the wrong spot. iacv and tps. I believe it was these two. Are you getting any kind of codes? That would be a good place to start and go from there.
juicedz is offline   Reply With Quote
b16a problem ls vtec teg Engine Building 17 05-30-2011 03:50 PM
B16A CEL Problem EG6Civic83 HYBRID -> EG-EK / DC 1 11-01-2006 05:39 PM
B16A ECU Problem Inseino ECU's, Electronics, and Tuning 10 10-31-2006 06:41 PM
Crx w/ b16a big problem need help please YouKnowWhoIBee HYBRID -> ED-EF / DA 7 07-17-2004 03:27 PM
B16a TPS Problem Jdubspeeds HYBRID -> ED-EF / DA 3 08-19-2003 04:55 PM
© 2001-2011 HondaSwap.com
a SkeyMedia network site | Advertise on Hondaswap.com
