B16A sir2 in 96 EK HELP!!!
Old 08-20-2004, 03:03 AM   #1
Rep Power: 0 BenSCP is off the scale
So I've swapped the engine in. Axles, linkages, mounts, and ECU are a go. Here's where I'm stuck. Forgive me if this has been asked before but I've searched all over the site and can't find the answer. I'm using the B16A sir2 ECU with an adapter to the stock EK OBD2a wiring harness. How do I wire up the Vtec solenoid and the oil pressure plugs? Also, are there any other problems I will be encountering? Any insight will be greatly appreciated...
BenSCP is offline   Reply With Quote
Old 08-20-2004, 09:19 AM   #2
Rep Power: 13 twisted civic is an unknown quantity at this point
http://www.hondaswap.com/gallery/ima...e36ffaae84.jpg
move your mouse over the pic and click the icon that appears in the bottom right corner to enlarge.
twisted civic is offline   Reply With Quote
