Hey guys, I'm wiring my b16 into my 92 civic cx today and there are to plugs on the engine that are empty, I think they're the o2 sensor and the knock sensor but not sure. One is green and is on the left side of the valve cover. The other one is white and on the underside of the intake. If anyone knows which one is which and what I need to do for the rest of the wiring that would help me out a lot, thanks.
B happy
Ride: dohc 95 egg
Knock sensor is on the back of the block. On the IM there is the IAC, Evap, TPS, IAT and MAP.
The green one on the side is the vtec pressure switch. __________________
Location: originally: Napa, CA now: Phoeniz, AZ (for school)
Green single wire left of the valve cover is the VTEC solenoid switch from pin A04 on the ECM. if it's a two wire, it's VTEC pressure (which is where the VTEC solenoid gets it's ground). if it's a tow wire, ground the white wire and run the other wire to pin D06.
The white plug is either IAT (intake air temperature or EGR). If it's EGR, leave it hanging, if it's the Intake air temp then you needf to plug it to the manifold, on the right, to the stationary female connector (assuming the motor is JDM). If you have a 99-00 Si, then it needs to be lengthened and run to the intake somehwere and you'll need to purchase the IAT sensor, lest you have it! Good luck!!! -Brian __________________
1992 "VX" (EG6) hatchback 1992 JDM B16A (P30 ECU by Mugen) 1996 CTR S4C LSD trans (4.4 final) Skunk II/Tokico 5 way adjustables C/F hood, Spoon Duckbill, JDM corners much, much more... Best Pass is: 13.72@101 |
#4 | |
B happy
Ride: dohc 95 egg
| ECU Pinouts | pissedoffsol | Reference Materials | 4 | 11-21-2007 10:46 AM |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| Help with Knock Sensor on B16a2 Engine | tdaddylove | HYBRID -> ED-EF / DA | 3 | 03-18-2004 02:21 PM |
| Knock Sensor Location B16 sirII 02 sensor | Gooseguir | HYBRID -> EG-EK / DC | 1 | 10-26-2003 04:43 PM |
| 85-87 ECU Error Codes | pissedoffsol | Reference Materials | 0 | 09-28-2002 01:29 PM |
