b16a swap in a 99 civic ex NEED HELP!!
Old 12-12-2007, 09:49 AM   #1
Ride:  99 civic w/ built b16
Rep Power: 0 na civic is on a distinguished road
myspace
Default b16a swap in a 99 civic ex NEED HELP!!
I have a 99 civic ex and i put a b16a motor in w/ a p2t ecu. I used my stock harness The car runs fine but im having issues w/ the distributer wiring. I cut the stock si plug off and rewired my stock distributer plug from my ex ( I left the dark blue wire not conected) but when i start the car it smells like some thing is burning or getting hot in the dizzy plug. I also put a high output alternator (165 amp stock is 70 amps) in it and i keep blowing the alternator fuse in the fuse box in the car! WHY???????????? is it to much amps?? or wiring???? is there ANY wires i have to pinout or change on the ecu? This is the first and last itme i ever try a swap myself
ANY ADVICE WOULD BE GREATLY APPRECIATED!!! NA CIVIC
na civic is offline   Reply With Quote
Old 12-15-2007, 07:58 PM   #2
Rep Power: 16 killercannible will become famous soon enough
First of all why would you need to rewired an si dizzy, if it is obd2 it is plug and play with you d series harness. Secondly your probably blowing fuses cause you have some crazy ass alternator meant for high output sound systems and it is producing too much power for your stock fuse block to handle.
Got my swap!!! Needs to be faster.
killercannible is offline   Reply With Quote
Old 12-16-2007, 10:05 AM   #3
dtob's Avatar
Rep Power: 11 dtob is an unknown quantity at this point
I would get the proper dizzy.
Like the above post says if you have a 99 civic and are using an obd2 dizzy/engine it should be plug and play.
dtob is offline   Reply With Quote
Old 12-16-2007, 03:38 PM   #4
drive it like U stole it
custompainter's Avatar
Ride:  99 dx coupe y8, 94 ex coupe z6, 89 teg zc,
Rep Power: 11 custompainter is on a distinguished road
check your wiring honda's are simple it's something stupid not much happens to these cars
i'd check the wiring on what ever you cut and spliced then i'd make sure you have enough grounds hooked up ( the wire from the motor to the frame of the car !!!! )
custompainter is offline   Reply With Quote
Info on a JDM B16A SiR2 swap into a 96 Civic DX spektrum HYBRID -> EG-EK / DC 9 04-27-2008 08:46 PM
99-00 civic Si cluster swap into EF How To (pics0) B18C5James HYBRID -> ED-EF / DA 30 07-11-2007 06:25 PM
CRX / 88-91 Civic Hatch B16a swap timeslips? The_MATRIX Racing and Driving Techniques 19 06-18-2007 03:56 AM
JDM B16A 88-91 CIVIC SWAP FORSALE JDM91SIR Parts: For Sale/Trade/Wanted 0 11-28-2004 05:43 PM
JDM B16A OBD1 Swap in 95 Civic EX CivicSiR7 HYBRID -> EG-EK / DC 4 02-13-2004 07:26 PM
