b16a2 into 98 DX, what mounts?
Old 09-22-2004, 08:48 PM   #1
Rep Power: 0 speedehatch is off the scale
All i need is a list of all the mounts/ brackets i need to put a USDM 99-00 Si motor into my 98 civic hatchback DX. If you could provide the part numbers that would be awsome but i just need a list of what i need.
Also with wiring is this correct and will it work: wiring my DX for vtec and use a OBD2a - OBD2b conversion harness connected to a 99 Si ecu.
speedehatch is offline   Reply With Quote
Old 09-23-2004, 01:31 AM   #2
Rep Power: 16 mrnice1058 is off the scale
Send a message via AIM to mrnice1058
well you are going to have to order the driver side mount from hasport or something but the rest you can use from the94-01 integra and the 99-00 si this is why
http://home.att.net/~eddsp/6gswap.html
besides that i would sell the ecu and get a chipped p28 and go that way it is easy to do it that way if you need help let me know
started but running pretty rought have any advise pm me and let me know!!
mrnice1058 is offline   Reply With Quote
Old 09-23-2004, 06:44 AM   #3
Rep Power: 13 twisted civic is an unknown quantity at this point
I used all the dx mounts, with the Si rear mount bracket that mounts to the front subframe. Both front roll stabilizer mounts from the dx too. I also used the pt2 99 si ecu, and it works perfect.
You don't need to buy anything to mount it except the rear bracket.
Use the Si shift linkage, but you need to get the hardware (bolt and large washer) from the 99 Si to bolt it up to the tranny, because it's a different mounting style than the dx and your factory hardware wont work. I didn't know that during the swap and ended up having to rig it up to work and baby it around until the part came in. I was so eager to rev it hard but I was afraid the linkage might come apart in front.
twisted civic is offline   Reply With Quote
Old 09-23-2004, 09:32 AM   #4
Rep Power: 19 smooth_criminal is off the scale
This is the worst hack job i've ever seen in my life
You hate me because i'm different;
I hate you because your all the same!
G-Driver.
smooth_criminal is offline   Reply With Quote
Old 09-23-2004, 10:50 AM   #5
Rep Power: 16 ryanwolfe911 is off the scale
Send a message via MSN to ryanwolfe911 Send a message via Yahoo to ryanwolfe911
Originally posted by smooth_criminal+Sep 23 2004, 08:32 AM--><div class='quotetop'>QUOTE(smooth_crimi nal @ Sep 23 2004, 08:32 AM)</div><div class='quotemain'><!--QuoteBegin-mrnice1058@Sep 23 2004, 12:31 AM
[/b][/quote]
no shit
[color=red]If 4 out of 5 people suffer from diahrea, does that mean 1 person enjoys it?
ryanwolfe911 is offline   Reply With Quote
Old 09-23-2004, 11:36 AM   #6
i wasn't saying to hack what i mean is to see the mount because if you do it wrong it is going to cost you in the end the only thing to do is to get the driver side mount from hasport when it comes to the 96-00 civic i was just showing the example of why the mounts will not work
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
