B16a2 into 99 civic Ex
Old 08-02-2004, 06:10 PM   #1
Rep Power: 11 99EJ8 is off the scale
First all of whats up guys im new my names cody but yah i recently just bought a 1999 b16a2 and im swappin it in to my 99 civic ex i was just wonderin what motor mounts to use, im thinking Si going off of your 6th gen basic swap over view but then i get confused cause it says use some of the rubbers that were on the old mounts, and its sayin that the si ac bracket wont work and i need a del sol one so maybe some of you guys can clear all this up for me thank you .
cody
99EJ8 is offline   Reply With Quote
Old 08-03-2004, 12:21 PM   #2
Location: On the Proverbial picked fence of Insanity.... aka..Baltimore Maryland
Rep Power: 23 mdlax1 is an unknown quantity at this point
Send a message via AIM to mdlax1
been answered 100x del sol bracket you can use si mounts but i wouldn't but aftermarket ones
mdlax1 is offline   Reply With Quote
Old 08-03-2004, 01:06 PM   #3
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
... huh??
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline   Reply With Quote
Old 08-03-2004, 01:43 PM   #4
Rep Power: 20 smooth_criminal is off the scale
what you'll need is the the SI front tranny bracket, driver side bracket, and rear bracket. The top tranny bracket can be used off of your stock motor. and like you said a DOHC del sol AC bracket. you can use all your stock mounts ( meaning the actual mount 'rubber part' the brackets are the peices that bolt to the block). But as Eric said you sould buy some aftermarket rubber.
You hate me because i'm different;
I hate you because your all the same!
G-Driver.
smooth_criminal is offline   Reply With Quote
Old 08-03-2004, 02:40 PM   #5
Alrite i went to honda today to get some parts and the guy behind the counter is tellin me that my power steering pump from my ex wont work ? is that true or is that guy talkin out his ass ?
Old 08-03-2004, 03:04 PM   #6
well you should be using the one from a SI. Your d-series pump and bracket are not going to bolt to the SI block. As well as anything else. No D-series specific parts will bolt to the B-series block.
G-Driver.
Old 08-03-2004, 06:30 PM   #7
So the ex pump wont work on the si bracket ?
Old 08-03-2004, 11:13 PM   #8
2265787829
2000Si's Avatar
Going off smooth criminals post, no it won't.
Old 08-04-2004, 12:41 AM   #9
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
yep. When I did my swap, I wanted to keep it clean and not remove the PS, also keeping the fluid from going EVERYWHERE. I found a way to remove and drop in the engine without disconnecting the PS pump from the lines. I then tried to bolt it up with no luck. oh well, then looped it 5 minutes later. You need a b series PS pump
also, I recommend not going to honda for all of those brackets. Its going to cost you a ton. search on Honda-tech classifieds or junkyards or somewhere like that. Spending 70 a bracket is just horrible.
Collin
Material Science and Engineering
Michigan Technological University
Old 08-04-2004, 01:20 AM   #10
Alrite thanks man and thanks to everyone else who has replied and helped me out.
Old 08-04-2004, 09:21 AM   #11
wth? AC / PS what do you need all that for?
Old 08-04-2004, 09:24 AM   #12
if you cant' find the brackets/mounts go to www.hondaautomotiveparts.com it's still pricy but cheaper the the dealer.
G-Driver.
Old 08-06-2004, 03:28 PM   #13
Yah i ordered em all from there thanks man
