B16a2 (obd2b) into 92 si hatch (obd1)
Old 08-04-2005, 08:21 PM   #1
clevisR6 is off the scale
What exactly would be required as far as wiring to swap in the b16a2 (from an 99 si) into a 92 si which is obd1? i've looked around and read conflicting info.
and what are these conversion harnesses? do i need the 99 si engine harness?
thanks
clevisR6 is offline   Reply With Quote
Old 08-07-2005, 04:30 AM   #2
thanks
ok, i think i found some info:
the 99 si harness is a one piece, so not good for swap?
so,
1. can i use the eg harness with a adaptor harness from hasport? would anything else have to be modified; injector plugs, alternator plug, etc?
2. or would i be able to use a obd2b integra harness since tegs and eg's are the "same" sort of? would they be 2 piece harnesses also? would i need a hasport adaptor? if so, which one?
Old 08-10-2005, 04:57 AM   #3
VTECin5th's Avatar
VTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of light
Send a message via AIM to VTECin5th
98 Type R or GSR harness.
99.5% plug and play, no component changing required.
2 wires for IAT need to be extended.
Rear ANDDD side motor mount BRACKETS from a 95 GSR.
LS axles.
VTECin5th is offline   Reply With Quote
