b16a2 wiring
Old 08-26-2003, 02:45 PM   #1
Banned
horsedangler is off the scale
I have a 95 ex coupe and I am dropping a jdm b16a2.
is the only thing I need to wire up extra is the knock sensor.
the swap came with the harness but it is cut. should I just use my stock harness
and wire up knock sensor. or attempt to install and splice together new harness?
horsedangler is offline   Reply With Quote
Old 08-26-2003, 03:16 PM   #2
seanjuan's Avatar
Ride:  See sig.
seanjuan is off the scale
first off if it's JDM then it's just B16a not B16a2, only usdm got the number designators
yes, use the harness off your motor
I did the same swap and it was simple, plus you don't want to be splicing and soliering wires unless you absolutely have to because it promotes corosion.
the JDM harness is backwards anyway so it's no good to you execpt for extra wires
good luck, you'll enjoy it when it's done for sure
seanjuan is offline   Reply With Quote
Old 08-26-2003, 04:01 PM   #3
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Unfortunetly, if it is an OBD IIb 99-00 ti won't plug up using your OBD I harness.
Old 08-26-2003, 04:18 PM   #4
Banned
They are both obd1
Old 08-26-2003, 04:25 PM   #5
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Then just use the EX harness, extend the o2 and run a knock wire to the proper pin.
But really, does it say B16A2, or just B16A?
Old 08-26-2003, 04:28 PM   #6
Banned
B16A IT IS A JDM SIR-2
do you know what pin on ecu (p30)
Old 08-26-2003, 04:34 PM   #7
Banned
I have a p28 and a jdm p30 ecu which ecu should i use? will my factory harness plug into the p30?
Old 08-26-2003, 05:15 PM   #8
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
P30 will plug right in, and you want to use that one. Goto the articles tab up top, page four I believe, there is a pinout for P30/P28's
Old 09-09-2003, 05:42 PM   #9
dhondagini is off the scale
I installed a b16a into a 93 ex and I am using a p30 ecu. The pinout diagram says that the knock sensor wire is d3, but all the forum posts say to use b19 which there isn't a b19 prong on the ecu, the b clip has only 16 prongs.
Did you have any success?? can you tell me what to do?
email me back to dhondagini@hotmail.com
thanks
dhondagini is offline   Reply With Quote
Wiring Question on B16A2 spooncivic01 HYBRID -> EG-EK / DC 2 09-29-2003 12:56 AM
Need B16a2 Ecu Wiring Diagram woo HYBRID -> EG-EK / DC 0 05-03-2003 11:07 PM
I Need A B16a2 Wiring Harness Lateral4 Parts: For Sale/Trade/Wanted 6 04-16-2003 06:07 PM
Jdm B16a2 Wiring Problem Lateral4 ECU's, Electronics, and Tuning 4 04-14-2003 02:04 PM
Wiring Help W/ B16a2 badnasty HYBRID -> EG-EK / DC 2 01-26-2003 04:31 PM
