b16b or a into EK coupe 96 (d16y8 engine) - belts ???
Old 04-09-2007, 02:24 AM   #1
Rep Power: 7 loverboy is on a distinguished road
Default b16b or a into EK coupe 96 (d16y8 engine) - belts ???
Hey guys !
My engine swap is going to be one from this 3 options :
1. b16b CTR.
2. b16a from civic SiR II.
3. b16a2 from civic Si.
Wich belts should i buy (timing,AC,power steering...) from which car that will fit the engines and my car?
Where can i buy these belts ?
Thanks
loverboy is offline   Reply With Quote
Old 04-09-2007, 02:26 AM   #2
AHHVTEC's Avatar
just buy 99-00 civic si belts and i would go with the b16b
Old 04-09-2007, 02:28 AM   #3
The Si 99-00 belts will fit all engines above ?
Where can i buy them (trough the internet)?
Thanks !
Old 04-09-2007, 02:30 AM   #4
AHHVTEC's Avatar
yes and you can buy them at any parts place but i would go with oem honda parts
Old 04-09-2007, 02:32 AM   #5
Is there any more parts related to the belts that i need for the swap ?
Old 04-09-2007, 02:42 AM   #6
AHHVTEC's Avatar
alternator belt, and while you at it change the water pump for a new one
Old 04-09-2007, 03:34 AM   #7
Thanks for the help my friend!
I have one more qestion:
Usually a p/s pump comes With the new engine, but do i need to replace the p/s pressure line that goes from the top of the pump to the p/s rack ?
If i do need, which pressure line will fit ? the one from the same engine (b16b/a) that im using for the swap, or any pressure line from b16/18 will fit ?
Thanks.
Old 04-09-2007, 03:47 AM   #8
AHHVTEC's Avatar
im not sure on that one ill try to get some other guys to look for ya
B16B / B18C Engine TuneUp KraZcyLoK0 General Tech and Maintenance 7 07-01-2006 03:01 PM
Would A S2000 Engine Fit In Me 93 Civic Coupe? 93redcivic HYBRID -> EG-EK / DC 2 01-11-2003 12:09 PM
B16b Civic Type R Engine? limpboy57 HYBRID -> EG-EK / DC 30 01-07-2003 12:21 AM
What is double clutching? Calesta General Tech Articles 0 12-27-2002 03:06 PM
Best Performing Engine for 98 Civic DX Coupe skunk2b18 HYBRID -> EG-EK / DC 1 11-11-2002 10:49 PM
