b16sir2 swap into a 1995 civic ex
Old 12-17-2006, 11:26 AM   #1
Rep Power: 0 jdm anthony is on a distinguished road
Default b16sir2 swap into a 1995 civic ex
hello, i have a question for this swap. very soon i will be getting my civic and im planing on getting the b16 built for boost, (sleeved pistons rods studs valves crankshaft everything..) and i just had a basic question:
what all is needed to get the b16 to work?
axles- where can you get high hp axles from also?
b series motor mounts
shift linkage
does it need throtle cables? or anything else for the swap?
thanks, anthony
jdm anthony is offline   Reply With Quote
Old 12-17-2006, 11:35 AM   #2
drew_23's Avatar
Ride:  95 Civic
Rep Power: 7 drew_23 is on a distinguished road
Send a message via Skype™ to drew_23
you will have to get a new throtle cable you can use the 99-00 civic si throtle cable, you can use a 94-00 integra shift linkage. i did the same swap
drew_23 is offline   Reply With Quote
Old 12-17-2006, 10:30 PM   #3
VTECin5th's Avatar
Rep Power: 41 VTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of light
Send a message via AIM to VTECin5th
Thumbs up
shift linkage
thanks, anthony
The question somewhat depends on the generation of b16 you're swapping into the civic.
You have an Ex, so you can use your rubber mounts, you'll need integra mount brackets though.
Use OEM axles, otherwise-go Hasport.
You can use the stock D-Series throttle cable, you just need to modify the bracket it sits on.
Without knowing the year of your b16 (obd specifically) it's hard to say what wiring will be needed, if any.
k20dc5
VTECin5th is offline   Reply With Quote
Old 12-20-2006, 08:03 PM   #4
the b16 sir2 obd1 i believe it is.
Old 12-23-2006, 11:38 PM   #5
any more help?
also, does anyone know what obd a 95 civic is? any more info and help will be greatly apprecated
also how much HP can stock motor mounts and stock axles handle?
Old 12-24-2006, 02:41 AM   #6
AHHVTEC's Avatar
Rep Power: 268 AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
the 95 civic is obd1..
Old 12-24-2006, 07:38 AM   #7
VTECin5th's Avatar
Yes, but sometimes people confuse B16 sir II with b16a2 and the brackets are different and the obd is different. If you have the SiR II, it's a direct bolt in. (With B series shiftlinkage and B series Axles)
any more help?
Yes, 95 is obd1.
You'll be fine with stock motor mounts and axles if you plan to keep it stock. I'd look into upgrading mounts after 160-180whp,and axles after 250whp.
k20dc5
Old 12-24-2006, 12:44 PM   #8
ok thanks this helped
and the motor i plan on ordering is the jdm b16 sir2
is hmotorsonline.com a good website? ive only heard positives from people who've bought from there.
Old 12-24-2006, 12:52 PM   #9
VTECin5th's Avatar
And that's all you will hear, they have built a great reputation for themselves.
You can't go wrong.
k20dc5
Old 12-24-2006, 01:00 PM   #10
ok, should i get the LSD trans?
Old 12-24-2006, 01:03 PM   #11
VTECin5th's Avatar
Absolutely.
Especially if you have the money to get it now, if you decide you want it later, you'll be kicking yourself in the ass.
k20dc5
Old 12-24-2006, 01:24 PM   #12
ok thanks, ill be posting once i get my car and my engine for more help!
K20A swap into a 92 Civic 92PWR HYBRID -> EG-EK / DC 36 11-27-2008 01:48 PM
99-00 civic Si cluster swap into EF How To (pics0) B18C5James HYBRID -> ED-EF / DA 30 07-11-2007 06:25 PM
01 Civic SI - What can I swap Stanage HYBRID -> EP / DC5 8 05-11-2004 01:44 AM
1995 Civic Cx with a B18A1 swap 95hatchcx HYBRID -> EG-EK / DC 4 09-10-2003 01:21 AM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 04:43 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
