Hey guys, kinda new here.
i am doing a b18 swap into a 96 civic hatch and I have no idea what motor mounts to use. i know I need the 99-00 civic SI rear lower but other then that I am stuck. any info would be cool thanks Griffin |
You can use the stock Civic Drivers side mount and use the passenger side mount as well, But usually they are worn after a few years, get some HCP replacement mounts they are cheap and will last, you can get em for about $300
#4 | |
B happy
Ride: dohc 95 egg
#5 |
I'm using the stock mount on the left side.It is liqiud filled and sucks for the b18. To much power.If your on a budget then use it if you have the money buy the Hasport mount kit for the left it's a new bracket and a b18b mount NICE!!!!!
#6 |
FüK-VTEC
Ride: 07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
hasport>>>all others.
also, on the back mount, if you use the urethane part that came with your car, you might have to modify it a li'l. i had to grind the edges of the bolt hole of mine down, to make it narrower. dont know if that's a common problem or not.... |
#7 |
i did this swap into my 96 hatch ....i changed my rear engine BRACKET not mount and the front right tranny bracket, again not the mount.......and on the driver's side i had to change the braket with the 2 holes for the mount bolts (the bracket thats actually on the engine under teh cam gears)
#8 |
FüK-VTEC
good lord dude, a mount is a mount.
bracket, mount, whatever. if you have the rear BRACKET from the b18, you'll have everything you need. everythign else can be used from your d-series. |
#9 |
i did this swap into my 96 hatch ....i changed my rear engine BRACKET not mount and the front right tranny bracket, again not the mount.......and on the driver's side i had to change the braket with the 2 holes for the mount bolts (the bracket thats actually on the engine under the cam gears)
#11 |
Banned
IF YOUR CAR IS AUTO RIGHT NOW U NEED TO GET ALL SI MOUNTS AND BRACKETS IF IT STRAND U CAN USE ALL THE MOUNTS AND BRAKETS FROM THE EX ITS THE SAME AS SI ONLY THING IS THAT U WILL NEED THE REAR TRANY BRACKET FROM A 99-01 SI I GOT A B18C1 IN MY 96 COUPLE AND I WENT THROUGH HELL TO ; ONE LAST THING IS THAT U NEED THE SI BRACKET THAT IS ON THE LEFT SIDE OF THE MOTOR WHICH LOOKS LIKE TWO FORKS STICKIN UP THE FORKS ON THE GSR ARE SAMLLER THAN ON SI ; SO U CAN PUT THE TOP LEFT MOTOR MOUNT
| b18 in 92 civic hb | dok | HYBRID -> EG-EK / DC | 5 | 06-17-2004 12:38 PM |
| civic 2000 ek...how much does it weight with a b18 | xhz973 | HYBRID -> EG-EK / DC | 2 | 04-29-2004 01:14 AM |
| Anyone here? | 2000Si | Members' Lounge | 14 | 12-09-2003 11:55 AM |
| My 96 Civic and B18 is sick plz help??? | 96coupeb18 | Engine Building | 8 | 10-19-2003 10:45 AM |
| everything needed for b18 swap | PLRacer | HYBRID -> EG-EK / DC | 1 | 10-10-2002 09:17 PM |
