b18a or b18b
Old 12-08-2003, 05:31 PM   #1
Rep Power: 13 emomelodic is off the scale
Send a message via AIM to emomelodic
so i have a chance to get a b18a block and a gsr head for cheap, to start the ls vtec swap.. do you reccomend it?
anyone know exactly everything you need for the swap to get it going in a 94 civic asap?
ecu..harness..linkage..gaskets...cl utch..flywheel..tranny...what else?
thanks
another question... which isbetter for ls vtec
the b18b, b18a or the b20?
emomelodic is offline   Reply With Quote
Old 12-08-2003, 05:32 PM   #2
Rep Power: 20 ef9civicgen4 is off the scale
you have to add a knock sensor to the block...
Current: B16A1 SiR-1, w/ ACT Clutch (Street disk w/heavy pressure plate), Short Ram Intake, OBX exhaust w/ high flow cat, Falken Azenis 195/60/14's
Best Quarter Mile R/T.134, 60' 2.278, 330' 6.120, 1/8 9.345 , MPH 76.09, 1000 12.129, 1/4 14.501, MPH 94.76
Turbo Kit: $?
Turbo Status: CRPfab Ramhorn Manifold, Garret T3/T4E Turbo(Brand New), Greddy TypeS, TiAL 38mm Wastegate, DSM 450cc injectors, OBD1 conversion
Current Savings: $400
For Sale: 3" Downpipe w/electric cut-out : $305 shipped
ef9civicgen4 is offline   Reply With Quote
Old 12-08-2003, 05:39 PM   #3
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
no you dont
just use a chipped P28
get the thing tuned and use good gas
МОΛΏΝ ΛΑΒΈ
Old 12-08-2003, 08:34 PM   #4
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
i use a b18a / p28 / hondata
fuck a knock sensor...
pills_PMD is offline   Reply With Quote
Old 12-08-2003, 08:58 PM   #5
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
knock sensors suck.
ecu - chipped p28 or p30
harness - use your stock harness
linkage - LS or GSR
gaskets - i dunno...i would assume b-series gaskets.
clutch - Exedy stage 2 (Exedy is the bomb diggity)
flywheel - any b-series will work
tranny - same as flywheel (dont get an ls tranny)
what else - youre gonna have to get the head converted, as well as get an oil line kit. getting the head converted usually runs around $60, and the oil line kit is like $45 (thats what Jotech quoted me (Jotech = kenny tran))
get a b18b over a b18a....
b18a = more than likely more mileage than a b18b.
high mileage + high compression = bad.
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 12-08-2003, 09:01 PM   #6
get a b18a and bore it 25 over and slap in some new pistons... ahhh fresh new motor.
Old 12-09-2003, 08:58 AM   #7
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
exactly, thats what I'm doin, also what should I tell the machine shop to do when I bring them the block, should i bring them the head also.
I know that the oil passage on the head needs to be either tapped or welded up. and i think the dowel pins need to be moved. When I get arp head bolts..should it be for the head or the block.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 12-09-2003, 10:21 AM   #8
FüK-VTEC
civicious's Avatar
you, like, get the head drilled, i think.
CMRA #265
AIM: greyfades
Old 12-09-2003, 10:43 AM   #9
http://www.c-speedracing.com/howto/lsvtec/lsvtec.php
you want arp rod bolts and head studs
Old 12-09-2003, 01:16 PM   #10
I didnt know you could bypass the knock sensor, what it is the p28 out of?
90 Integra Sedan
B20V 225 / 153
Old 12-09-2003, 01:18 PM   #11
FüK-VTEC
civicious's Avatar
1992-1995 Civic EX/Si / del Sol Si
1992-1995 Del Sol Si/Civic Hatchback Si/ Civic EX
CMRA #265
AIM: greyfades
Old 12-09-2003, 01:28 PM   #12
The Trisexual
wont a p28 run a fucked up fuel map for an lsvtec?
Current Rides
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
253whp
Old 12-09-2003, 05:09 PM   #13
that's why you buy a hondata and i give you my fuel map / ignition maps for it that i wasted 4 hours worth of dyno time making
Old 12-09-2003, 05:41 PM   #14
The Trisexual
bet u could sell those on ebay.$25 a peice
Current Rides
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
253whp
B18a and B18b info please importjdmcivic HYBRID -> EG-EK / DC 13 06-19-2008 02:39 PM
b18a and b18b 91crx HYBRID -> ED-EF / DA 2 05-24-2004 06:20 PM
B18A and B18B 95hatchcx HYBRID -> EG-EK / DC 4 01-20-2004 06:33 PM
WTB: B18b or B18a short block in good condition leonc Parts: For Sale/Trade/Wanted 0 01-12-2004 04:13 PM
B18b Head On B18a Block? Ractive78 HYBRID -> EG-EK / DC 3 01-16-2003 03:07 AM
