I have a B18A and am going to buy a b18B.
I am going to put the B18B in my 95 hatch CX Can i use the drive axles, motor mounts, and shift linkage from the B18A to put on the b18B or do i need all b18B parts? How many motor mounts will i need for the swap? |
if you have a b18a and your going to a b18b the mounts should still work. I'm pretty sure integra's use the same mounts from 94-00 so they should work. the shift linkage also should be fine. the axles should also fit if the motors are the same years. is the b18a in your car now?
DD: s13 sr20det 99' civic si (ebp) turbo- stolen SOLD: 00 integra type r #0282 je pistons, eagle rods, aebs sleeves, bored to 84mm, 9:1 compression, t3/t4 turbo custom piping, exhaust and much more............ sold: 95 si hatch lsvtec turbo ,skunk 2 exhaust ground control coilovers, gsr blades wrapped in falken azenis rubber,walbro 255 fuel pump, apexi safc, 450cc dsm injectors, carbonfiber eyelids and front lip, itr interior, apr carbonfiber mirrors....... |
if the b18b is a 95 you can use your civic rear mount I used mine when I did my type r swap. but you will need a tranny mount and a driver side engine mount from a 94-00 integra. the axles also need to be 94-00 integra axles.
#5 |
B happy
Ride: dohc 95 egg
If you use the B18A axles, you HAVE to use the B18A halfsahft also. The joint is different on the 94+ tegs.
| B18a and B18b info please | importjdmcivic | HYBRID -> EG-EK / DC | 13 | 06-19-2008 02:39 PM |
| b18a and b18b | 91crx | HYBRID -> ED-EF / DA | 2 | 05-24-2004 06:20 PM |
| swapping the b18a or b18b into the hatch | Slammed90Lude | HYBRID -> EG-EK / DC | 4 | 01-22-2004 04:22 PM |
| b18a or b18b | emomelodic | HYBRID -> EG-EK / DC | 13 | 12-09-2003 05:41 PM |
| B18b Head On B18a Block? | Ractive78 | HYBRID -> EG-EK / DC | 3 | 01-16-2003 03:07 AM |
