Its the NUGE!
yeah i have a B18a in my civic but....i could get my hands on a B18b for real cheap and i am just wondering.....i know the specs of the B18a and B18b and i just want to know what is exactly the difference between the early B18a and B18b to have a different horsepower and torque rating.....does the B18b have a better flowing head or something? And can i swap a B18c head on my B18a block? Is there a difference between the B18a and B18b that would make an Ls/Vtec swap harder?.....oh and the B18 in my civic is from a 90 integra....yeah i know....
Ever wonder what makes special sauce so special?.....yo.... |
B18A1 - 90-91 - OBD0(=90-91) 130hp/121lb ft TQ
B18A1 - 92-93 - OBD1(=92-93) 140hp/121 lb ft TQ B18B1 - 94-01 - OBD1(=94-95)-2A(=96-98)-2B(=98-01) 145hp/127lb ft TQ differences between all ls engines are: intake manifold, cams, exhaust header, electronics (obd generations) __________________
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
#4 | |
ENGINEERING RS-LS-GS Engine Type 1.8L, DOHC, 4-cyl., 16-valve HP, SAE net 140 hp @ 6300 rpm Torque: 126 lbs-ft (17.4 kg-m) Redline 6500 rpm Bore & Stroke 3.19 in x 3.50 in (81mm x 89mm) |
#5 |
B happy
Ride: dohc 95 egg
Interesting, I just realized there is no Japanese B18A, hmmm....
oh yea, that is correct 17.4 kg, an it's 125.8544392, rounded up to 126 lbs-ft ![]() __________________
#6 | |
ENGINEERING RS-LS-GS Engine Type 1.8L, DOHC, 4-cyl., 16-valve HP, SAE net 140 hp @ 6300 rpm Torque: 126 lbs-ft (17.4 kg-m) Redline 6500 rpm Bore & Stroke 3.19 in x 3.50 in (81mm x 89mm) [/b][/quote] I pulled it from our reference section, B take heed to this post... good info here... 92b16vx, the B18A1 is a US motor. The B18B was Japanese woot, obviously now that you know that. ***EDIT - Sorry 92b16vx*** __________________
#7 | |||
B happy
Ride: dohc 95 egg
Calesta, the B18A1 is a US motor. The B18B was Japanese woot, obviously now that you know that. [/b][/quote] I'm not Calesta, and I knew the B17A1 was US only, but never paid attention to the B18A1. __________________
#10 |
B18B1-DC2
i was or still planning to put in the JDM B16A P30 81mm pistons into my b18b block with eagle lighten crank and H beam rods, notch my block is the must with bigger rods would anyone have a better suggestion on pistons? keep in mind building an all motor engine. all suggestions are much apreciated
#11 |
Brutal Moderator
Ride: 97 Integra LS Coupe
Do you realize this thread is 4 years old dude? Don't bring back dead conversations, just start a new one...
#13 |
Brutal Moderator
Are you kidding me? Did you not see that this thread is 4 years old and that I just chastised the other guy for bringing it back to life? Start a new thread moron...
#14 |
Führer Mod
