New to the forum here, but this looks like a place a can find answers to my questions. I have done some searching and I seem to get mixed opinions. So, I am putting a 98 ls motor in my cx. Question being do I have to use the ls ecu and just rewire the plugs on my harness, or would it be better just to switch the whole harness. I am also swaping to the integra dash also(I got the whole car for $900). Up until now I have always been in the Evo/DSM crowd with my Evo and know alot about that but hardly anything about this. Just looking for some guided help. If anyone lives in Columbus, Ohio, some hands on help would be nice too. Any help is appreciated!!
Ancient Member
Ride: RHD EG6 jrsc b18c :)
1998 acura integra LS motor will drop right into a 95 cx, and the wiring harness off the engine will plug right into the cx chassis at the shock towers.
Use the throttle cable from the integra, also use the axles, shift linkage and all engine mounts. make sure that when you remove the cx engine from the car that you don't open the clutch hydraulic system, just simply remove the clutch slave cylinder from the cx tranny prior to engine removal and hang it out of the way. you are going to need a radiator out of a 94-97 del-sol dohc vtec, or out of a 99-00 civic Si dohc vtec. use the integra radiator hoses with this radiator. You will also have to get an obd1 integra LS ecu p75 I think (check under swap info in the refrence section for the 94-95 integra obd1 ecu), the 98 ecu out of the integra will not work due to it being obd2 and the car being obd1 the honda civic CX used a 1 wire 02 sensor so you will have to run new wires to the ecu for the 02 sensor, you can find the ecu pinouts in the refrence materials section at the top of the forum Swapping the dashboard into the civic will have its own set of problems with fitment and possibly wiring, I haven't done the integra dash into a civic, but I have seen it done, I do know however that there will be fitment issues with the door panels and the dash. Also, if you want a good upgrade, remove the front steering knuckles with the rotors and calipers from the integra and put them on the cx, it will give you a larger disc brake in the front you can also remove the rear suspension from the integra and put that on the civic and have 4 wheel disc brakes. (direct bolt on and you will get to use the rear sway bar if you want) if you really want to go wild you can take and remove the radiator support from both cars, (lots of drilling) and put the integra radiator support on the civic (lots of welding) then take the hood with the brackets from the integra and put that on the civic, then the headlights, front bumper and fog lamps (if equipped). then take the fenders and have someone who is really good at body work cut the fenders and weld them together and do all the body work and then you can have a full integra front clip on your car. the possibilities are endless. Have fun and ask any questions that I haven't answered in the forums. Last edited by welfare; 08-29-2006 at 09:06 PM. |
I really appreciate the help. I am doing both the front and back brake swap with an aem upgrade in the front! I have a full Integra to work with here, so any part i need is available. But like I said if anyone in the Columbus, Oh area with experience would be willing to come over and help out a little bit, I would be very thankful. I am dumping alot of money into this car and I want it to be right!
| wiring obd1 b18b into 96 dx hatch need help asap!!!!!!!!!!!! | boostedek9 | HYBRID -> EG-EK / DC | 2 | 07-25-2006 07:08 PM |
| looking for b18b n b18c wiring diagram | 95_teggygsr | HYBRID -> EG-EK / DC | 1 | 06-24-2006 02:41 AM |
| b18b wiring harness | 92si | HYBRID -> EG-EK / DC | 3 | 12-07-2003 10:48 PM |
| B18B in 92 CX wiring ? | dansace | HYBRID -> EG-EK / DC | 11 | 07-18-2003 04:54 PM |
| Wiring Up B18b In 1993 Cx | grinnis | HYBRID -> EG-EK / DC | 2 | 05-06-2003 03:52 AM |
