B18B into EG (Mount related)
Old 06-19-2006, 02:13 AM   #1
Rep Power: 0 ApAthY is off the scale
Default B18B into EG (Mount related)
So I have pulled the B18 out of my integra one or two of the mounts are in pretty crappy condition and I just wanted to clarify before I ordered new mounts:
I've read that I can use some of the EG mounts w/ the B18 mounts and I've also read that I should replace all the EG mounts with the B18 mounts. Not sure which one is correct; although I remember seeing a diagram (that I can't seem to find anymore) that showed which mounts needed to be EG and which needed to be B18?
Also, My block has "B18B" engraved in it and not "B18B1", is there any significance to this?
Thanks
For ease of calculations, we'll approximate this horse to be a sphere.
ApAthY is offline   Reply With Quote
Old 06-19-2006, 08:59 AM   #2
Ride:  93 del Sol Gas sipper
Rep Power: 95 asmallsol will become famous soon enoughasmallsol will become famous soon enough
B18B with no 1 on it means that you have a JDM engine, so you integra was swapped at one point.
As for mounts, you need all the Brackets from the integra (the rear bracket, the ac bracket, and the lower front transmission bracket) then for the rubber mounts, the rear subframe and the two on the lower frame rails can be of the civic veriety. The two upper mounts have to be from an integra.
Collin
Material Science and Engineering
Michigan Technological University
Old 06-19-2006, 09:23 AM   #3
could I just buy another set of OEM integra mounts and use all of those?
Old 06-19-2006, 09:49 AM   #4
Rep Power: 40 vtecsir1 is on a distinguished road
read what asmallsol wrote. all you need integra mount wise is the driver side, front tranny bracket, rear bracket and the rest are civic.
vtecsir1 is offline   Reply With Quote
Forum Jump
Tranny mount b18b into 92 civic please HELP! R33Civic HYBRID -> EG-EK / DC 1 06-10-2004 05:21 PM
Tech: Engine Mount Solidification Vexamus General Tech Articles 20 02-03-2004 09:13 AM
B18b Swap....NEED HELP DjMcPhatty HYBRID -> EG-EK / DC 14 10-07-2003 10:27 PM
93 Civic Ex Automatic Tranny Mount Location allmotord16rex HYBRID -> EG-EK / DC 1 06-14-2003 02:06 AM
Motor Mount Bracket, B18b Swap itsbigmike HYBRID -> EG-EK / DC 4 06-08-2003 09:26 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
