b18b obd2 in 95 civic
Old 10-02-2006, 11:46 PM   #1
Ride:  06 gmc 2500 Turbo Ls Civic
Rep Power: 30 igotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud of
Default b18b obd2 in 95 civic
First post so Hi
i have a b18b obd2 and want it in my 95 civic. i have a obd1 wire harness off a ls and want to use that 1. because i dont have the harness to the 0bd2 and 1 need to keep the ecu obd1. so far so good.
Q1. will the distributor from a 0bd1 work. i thinks so
Q2 same with alternator from a obd1 on my obd2.
Q3. under the timeing cover side of the engine there is a small plug that my harness dose not have a spot for. Under the belt pulley. i dont think i need that but im not sure. What is it.
Thanks. jsut need to clearify before i put it in and have a hard time making changes.
igotnothin is offline   Reply With Quote
Old 10-03-2006, 02:09 PM   #2
boostedek9's Avatar
Rep Power: 8 boostedek9 is off the scale
the plug on the alternator on a obd2 is square and on a obd1 its round. ill trader you your obd2 alternator and obd2 distributor for my obd1 1 alternator and distributor. the plug your talking about is the crank fluckuation sensor obd2 have it your ok and you do not need to plug it in just leave it hanging there out of the way and your all good let me know if you want to trade parts i really need obd2 parts thanks man email is turbohatch96@hotmail.com
boostedek9 is offline   Reply With Quote
96 B18b into 88-91 Civic Hatch wanderinman HYBRID -> ED-EF / DA 8 11-18-2006 06:22 PM
obd1 b16 in obd2 civic qtmac_mien HYBRID -> EG-EK / DC 3 02-21-2005 12:41 AM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
b18b civic problems Estorvito HYBRID -> EG-EK / DC 8 10-24-2004 05:37 PM
B18b Swap + Obd2 To Obd1 Conversion Baker HYBRID -> EG-EK / DC 5 02-28-2003 11:11 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
