B18b Swap + Obd2 To Obd1 Conversion
Old 02-28-2003, 09:12 PM   #1
Rep Power: 22 Baker is off the scale
Send a message via AIM to Baker
I have a 97 civic DX with a 99 usdm b18b. I did a obd2 to obd1 conversion using the skunk2 harness. I had a check engine light for coolant temp sensor (my moron friend put the wrong plug on it) The car was fine when I had the cel aside from low idle when cold and high idle when warm but now that I plugged the right plug in and eliminated the cel my headlights dim when I push in the throttle unless I'm above 4000 rpm's, they also dim at idle but if I rev past 4000 they will brighten back up. I've tested my alternator and battery and both are functioning properly. I have heard some other people having similar problems when using conversion harnesses I was wondering if anyone else had this problem or if they knew how to fix it.
Baker is offline   Reply With Quote
Old 02-28-2003, 09:33 PM   #2
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
????Why did you convert a OBD II engine in a OBD II car to OBD I???
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 02-28-2003, 09:44 PM   #3
Rep Power: 44 Domeskilla is off the scale
Your car is obd2 and you have an obd2 motor.. or wait.. that motor might be obdb (a.ka. obd3) and your car is obd2, that is why you used the harness adapter?
Anyways... check grounds, an alt can test good, but still be the problem (seen it many times).. check all electrical stuff (i.e. ignition componants, etc.)
For all your air suspension needs <a href=\'http://www.ultimatesporttruck.com\' target=\'_blank\'>Three Rivers Ultimate Sport Truck</a>
**There are many misconceptions of air ride and handling. A lot of bullshit spread, please PM if you wish to put air on your car/truck. You will get the 411. There ARE ppl who race with air ride, just have to know how to install it right.**
Domeskilla is offline   Reply With Quote
Old 02-28-2003, 11:04 PM   #4
car is obd2a and motor is obd2a I did the obd1 conversion for a few reasons, it makes the swap easier as you don't have to run a secondary O2 sensor wire and a few other wires. Also I will be turbo charging in april and in order to run hondata you have to be running obd1. I have checked all the grounds, I'll check the other stuff on sunday
Old 02-28-2003, 11:07 PM   #5
ah.. just some fyi.. Hondata now supports obd2
keep us up on what the problem is.
Old 02-28-2003, 11:11 PM   #6
lol, yeah they didn't in october when I did the swap also hey haven't come out with anything obd2 for the p75 from what I've seen and its still an obd1 ecu with obd2 plugs on it
Hondata has OBDI P28 ECUs modified with OBDII connectors. These plug straight into an OBDII vehicle with no adapter harness necessary. Available with OBDII A (96-97) and OBDII B (98-00) connectors.
Obd2 Car Obd1 Engine & Wiring SpeX ECU's, Electronics, and Tuning 16 01-10-2009 09:58 PM
B18B or B18C swap civicsi94 HYBRID -> EG-EK / DC 20 07-05-2004 07:11 PM
New P28 Chip, Obd2 To Obd1 Conversion Pewble HYBRID -> EG-EK / DC 2 03-31-2003 01:51 PM
Obd2 To Obd1 Conversion Pewble ECU's, Electronics, and Tuning 5 03-31-2003 11:32 AM
Pr3 And P28 With Obd1 Conversion D16z6CrxDx Parts: For Sale/Trade/Wanted 2 02-24-2003 06:39 PM
