B18B Swap Question Please Help!
Old 09-18-2004, 02:20 PM   #1
Rep Power: 0 EvilCamaroSS is off the scale
Ok.. I have a wrecked 96 Integra LS Automatic. As soon as i find a GSR or LS tranny for cheap I'll be swapping the D16Y7 motor out of my 97 Civic LX 4dr and swapping in the LS motor and tranny. I'm trying to gather up everything i need before i start the swap... So here is the scenario:
I have a wrecked (in the rear) 96 Acura Integra LS Automatic.
I have a 1997 Honda Civic LX 4dr 5spd.
What parts do I need out of the Integra and What parts do I need from an outside source to complete this swap? I'm talking a complete list sort of thing. Also Dont assume I know anything Pretend your telling a complete idiot what they need (I'm car inclined just not honda inclined).. Thanks for all info!
1998 Camaro SS
1997 Honda Civic LX
EvilCamaroSS is offline   Reply With Quote
Old 09-18-2004, 02:33 PM   #2
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
only extra things you will need, is flywheel clutch and linkage, rest is pull and then drop in.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 09-18-2004, 02:40 PM   #3
do i need motor mounts or ac brakets or anything liek that?
1998 Camaro SS
1997 Honda Civic LX
Old 09-18-2004, 03:21 PM   #4
Rep Power: 16 mrnice1058 is off the scale
Send a message via AIM to mrnice1058
yes you are i am doing almost the same thing i am doing a swap in my 97 4dr lx i am putting in a b16 tho this is what you are going to do is use the two mounts the one in the rear and the one for the tranny the one on the driver side is different then the bseries mount. you can use the mount that is in there but you are going to have to use a bracket from a 99 si not the mount the bracket that the mount goes from the engine block to the mount itself i have a web site for you
http://home.att.net/~eddsp/6gswap.html
this should help you out
and he was right all you need is the shift linkage the axles and the intermediate shaft and the ecu even the wiring harness you have will work fine
take the wiring harness out with the engine don't disconnect anything it will drop in and you can plug in right away if you need any help let me know and yes you will need a flywheel and clutch for your new tranny and make sure you put your flywheel to torque spec that your flywheel needs and also your clutch it is not hard but make sure you do it when the engine is out it makes it so much easier
started but running pretty rought have any advise pm me and let me know!!
mrnice1058 is offline   Reply With Quote
