I just finished my B18C swap into my 99 EX and i love it !!!!!!
i highly recomend it and it was very easy to install. were are you getting the motor from? mtry to get ECU,Axels, Shift linkage with the motor.... |
get the complete changeover from hmotorsonline
#5 |
you can use the the b18 one and also you can use the civic one.
i just depends on how much work you want to invest into it. i beleive using the b18 one is the easiest way to go....anyone correct me if im wrong... i personally have the b18c one in my car.. |
#6 |
Just use the civic harness..What trim is your civic (EX,DX....)?If you have an EX model its just a bolt-in process.If you have a DX or anyother non-VTEC model its just as easy but you need to wire VTEC.Your going to need a complete change over.Also i forgot,your car is obd2b(i maybe wrong,im a EF guy) so depending on the year of your motor you may need to change the obd of the motor.
#8 |
everything should just bolt up and wiring should be a plug n play process using either harness EX or B18, i believe its better to go with the B18 harness tho. as for the drive shaft, the only thing different is that you'll need a half shaft from 'teg or an equivelant b-series.
| b18c obd1 swap into 2000 civic cx | bago'ong billy | HYBRID -> EG-EK / DC | 4 | 11-15-2004 12:31 PM |
| Help me choose Civic for engine swap | arielb1 | General Tech and Maintenance | 16 | 06-17-2004 11:59 AM |
| Civic 95coup Ex Swap / Engine Suggestion | seriot | HYBRID -> EG-EK / DC | 23 | 06-17-2003 01:02 PM |
| Need Help For 91 Civic Engine Swap | sharkz | HYBRID -> EG-EK / DC | 5 | 01-13-2003 03:15 PM |
