| | LinkBack | Thread Tools |
| | #1 |
| Greenhorn Join Date: Oct 2009 Location: PA Age: 29
iTrader: 0 / 0% Ride: 92 civic Cx and 98 civic Dx
Rep Power: 0 | I have a 98'dx coupe, eventually going to put in a gsr b18c (when I find one)...what all mods or converter kits do I need to use here as far as wiring? Going to try and find one the same OBD....but if I get an OBD1 at a good price I jumping on it....anyone got any feedback? I'm guessing I need mods/converter kit to recognize the vtech and to convert the OBD difference if I go that route. |
| | #2 |
| FI FTW. | If you get an OBD1 GSR engine, you will need the following: OBD2A>OBD1 Jumper harness OBD1 P72 (GSR) ECU If you get an OBD2 GSR engine, you will need the following: OBD2 P72(GSR) ECU. The wiring is simple. You'll need to run wires for VTEC (pressure switch, and the solenoid itself), and you will also need to convert your IACV plug from a stock D16 (3 wire) to that of a B-Series which is a two wire. A writeup on that can be found here: http://www.ff-squad.com/tech/wiring/...-98_a-plug.jpg
__________________ Gym: Bulking. 170lbs as of 3/01/10. Goal is 180lbs. Car: 319.8whp currently. Goal is 400whp. School: Currently at SCC. Transferring to EWU Winter 2010. Major: Mechanical Engineering. |
| obd2 b18c gsr wiring harness | bsbllpss | General Tech and Maintenance | 0 | 11-03-2009 08:13 PM |
| Obd1 Vtec Wiring Harness B18c, B16, D15,d16, B20,type R | RSS-Bot | Auctions | 0 | 02-16-2008 08:03 PM |
| Obd1 Vtec Wiring Harness B18c, B16, D15,d16,type R | RSS-Bot | Auctions | 0 | 01-19-2008 01:33 PM |
| OBDI Integra GSR Engine Harness wiring OBD I 94-95 b18c | RSS-Bot | Auctions | 0 | 01-14-2008 10:13 PM |
| cx wiring harness on jdm b18c gsr need wirig help | Eg6nRpS13 | HYBRID -> EG-EK / DC | 5 | 09-13-2005 12:58 PM |
