B18C JDM Auto into 98 civic
Old 02-26-2008, 05:51 PM   #1
rdomeck's Avatar
Ride:  Anything with 4 wheels
Rep Power: 5 rdomeck will become famous soon enough
Default B18C JDM Auto into 98 civic
I'm trying to put a JDM B18C GSR engine and auto tranny into my wifes car. I am having a lot of clearance issues on the left frame rail. I am also having issues with the top mount on that side.
I have had to modify all the mounting brackets with the exception of the right lower transmission mount.
From there I had to shorten the lower front A/C engine mount by about an inch.
After that I was able to slightly modify the upper transmission mount on the right side. I have clearance everywhere excpet for the pulley on the crank shaft and the alt. pulley.
Has anyone done this swap?
I ready to start cutting and welding the left frame rail, but I'm a little supprized because everything I read said this was almost a direct bolt in!
Any help?
Thanks
1987 CRX Si-Stock
1998 Civic-B18C
2001 Suburban 2500-8.1 Big Block
1915 Model T Speedster-Original
1974 914 Porsche-Somewhat Original
Unlimited class 125cc Shifter kart
Previous toys
1985 CRX Si-D stock Champion
1986 CRX Si-Daily driver
1984 Wagoner-Tow vehicle
1968 Formula Vee
1995 Tahoe-Tow vehicle
1976 911-track car project
1986 CRX Si- Rust bucket for parts
1982 Dodge Rampage-Kind of still have in pieces
1989 Civic-DX
1984 GTI
1966 Ranchero
1984 Civic Hatch
1971 Karman Ghia
rdomeck is offline   Reply With Quote
Old 02-26-2008, 05:58 PM   #2
AHHVTEC's Avatar
yea im thinking something is wrong it should drop right in no cutting at all
Old 02-28-2008, 02:24 PM   #3
rdomeck's Avatar
Any other suggestions? I am using the civic mounts because Nagasaki JDM Motors did not send me anything they said they would! I am waiting on those mounts to see if things locate any better! Anyone who has done this swap may know the answers, I could use the help! Thanks
1987 CRX Si-Stock
1998 Civic-B18C
Previous toys
1968 Formula Vee
1989 Civic-DX
1984 GTI
1966 Ranchero
1984 Civic Hatch
1971 Karman Ghia
Old 02-28-2008, 02:27 PM   #4
AHHVTEC's Avatar
you have to mix and match stock mounts the normal d series mounts in your car will not work, that your problem..
Old 02-29-2008, 11:31 AM   #5
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
Wait until the mounts get there to try anything else. That is why its not setting up right. You need B-series upper driver side and T-Bracket to get it positioned correctly. Also need the torque moutns I believe.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
FS Civic & GSR B18C P72 swap parts head transmission linkage ecu parting out mikaleg6 Parts: For Sale/Trade/Wanted 43 02-02-2009 11:10 PM
F/S: Brembo Rotors, Buddy Club Spec II Exhaust, HF Calipers, D series Valve Cover RedArmy Parts: For Sale/Trade/Wanted 3 07-18-2008 07:45 PM
B18C GSR into 98 civic rdomeck Civic and del Sol - EG and EK 15 02-24-2008 11:08 PM
Auto to Manual Swap Mounts for 93 Civic Coupe EJ2 civic Civic and del Sol - EG and EK 2 01-19-2008 12:02 PM
94 civic 4 door auto tranny iknowchevyteachmehonda Civic and del Sol - EG and EK 7 01-22-2007 11:05 AM
