b18c jdm gsr or b16a sir2 in 5th gen civic
Old 02-18-2004, 07:53 PM   #1
Rep Power: 0 SalvotoreScarfo is off the scale
I heard it meaning less to put a h22 into a 5th gen civic because of the weight, unless you are drag racing and empty the inside out. My question is the jdm b18c or the b16a sir2 for the 5th gen civic. Thousand dollar difference, is it worth it. Express your opinions on both engines. Which would be able to consume more boost with out internals? Which one would swap easyier into a 94 civic dx coupe?
DEADMANDRIVIN
SalvotoreScarfo is offline   Reply With Quote
Old 02-18-2004, 08:23 PM   #2
UDT
Rep Power: 33 UDT is off the scale
Send a message via Yahoo to UDT
the B16 and b18 are going to be the most easy, the cheaper of the two would be the B16 only cause of the price of the motor, other then that their both gonna be the same swap as far as what fits. The h22 is a whole nother story the engine would be stronger then either the B16 or B18 and the prce of the motor would be the same as the B16 but see the H22 dont slap right in the civic, it requires alot of banging and making stuff fit so the swap price comes into play inless you intend on doing it your self but then experience comes into play and if you had what it took i dont think you would be here asking us these questions. My vote would be the B18 and only cause of the car its goin in, keep it simple for your own sake. They can all only handle about 6psi stock though 8 isint unheard of but its pushing it inless you are running a good fuel managementand, and if thats the case you could see 9 or or 10 psi on stock internals im sure with no problems.
By the way i almost couldint under stand a Fu*king thin your said.
no speaka da engrish? J/K
97 Acura integra GS-R
AEM cold air intake
Apex-i N1 cat back
Dc header
best 1/4 15.4
UDT is offline   Reply With Quote
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
B16A SiR2 into a 6th gen EK pissedoffsol Swap Articles 0 01-12-2004 02:13 AM
B16A SiR 1 into a 5th gen chassis pissedoffsol Swap Articles 0 01-12-2004 02:12 AM
Later 90's b16a into '88 Civic HB? Citizen_Insane HYBRID -> ED-EF / DA 1 07-24-2003 01:57 PM
All This Reference Material, And No Cel Code Chart Slo86GT Members' Lounge 5 06-13-2003 10:31 AM
