2265787829
Ride: Refer to my name, dumbass.
Ok I've been playin GT3 too much. The EK hatches are starting to grow on me. So...here's what I was thinking...(probably nothing new to anyone else here)
Somewhere in the 94-01 years of B18c1 GSR engines which is what I want to swap into an EK hatch from 96-00. I have a few questions. (some of which were already answered by TPP) 1. How much am I looking at for a used c1 which I'm going to rebuild and squeeze boost into anyway? 2. How much for a corresponding GSR tranny? (as if I get an EK with a D series, the tranny won't bolt up) 3. Would it hold the power if I decided to try to make 250 whp? 4. Would the GSR gauges fit in with little or no splicing? 5. Would hasport mounts be needed if the EK came with a D series? 6. Would my already acquired T3/T4 with .43 A/R be a good turbo for this application? Or would it be too small to get the power requirements as stated above? I'm sure theres more questions I'll have as you guys answer em. But thanks in advance...and don't stray from the topic...cause I just want answers and red flags to any problems I know I'm overlooking. ![]() |
FüK-VTEC
Ride: 07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
1. $2899 from hmotorsonline. you could prolly find it for cheaper thogh, check www.alljapaneseengines.com or ebay
2. tranny should come with the swap. 3. sure. you'd prolly have to build the block tho (pistons, rods, sleeves) 4. they'll fit, you gotta move almost every single wire around on the gauge cluster plugs though. http://www.fifthgearonline.com/installs/gsrcluster.htm <---thats what i used. i had to move the ground wire over 1 spot thogh. other than that, that's the best how-to i've ever seen. 5. no. you'll need a b-series back mount, and d-series driver and passenger side mounts. 6. i dont know shit about turbos. i dont see what'd be wrong with a t4/t3 though, it's still a turbo. |
#5 |
2265787829
Sweet thanks man. one more question I forgot.
Would I be getting the c1 ECU along with the engine or would I need to dig one up to keep from having to fuck around with the obd splicing/changing shit? |
#6 |
FüK-VTEC
for 3k you sure as hell had better get the ecu! lol
if you got the swap from hmotorsonline, it'd come with the ecu. |
#7 | |
2265787829
Thanks.. This thread will be saved for future usage |
#8 | |
#10 | |
FüK-VTEC
#11 |
jesus christ, the shit never ends............... Ek chassis's were made from 96-00 (and 01 in some markets) and the 92-95 civics are chassis code EG. Yes a B18, NO MATTER WHAT B SERIES, will bolt into an ek with the appropriate mounts for that chassis , e.g., Engine and tranny mounts for a 99-00 Si. That is unless of course you are using an earlier stlye cable clutch transmission, in which case you will have to purchase a cable to hydraulic adapter and mount kit from Hasport. If you buy an OBD 2 B16A it will all bolt in with no mods whatsoever, with the evception of wiring for VTEC and knock sensor if you do not have a VTEC equipped civic , i.e, LX,DX,CX. I say stick with a b16a, it's what belongs in a civic anyway.
[color=red]If 4 out of 5 people suffer from diahrea, does that mean 1 person enjoys it? |
#12 | |
2265787829
Thank you. Move along. |
#14 | |
[/b][/quote]You civicious still an a$$hole You 8k= 1. How much am I looking at for a used c1 which I'm going to rebuild and squeeze boost into anyway? Ethier you talking about nitrous, you dont Sqeeze turbo. |
#15 | |||
2265787829
Ethier you talking about nitrous, you dont Sqeeze turbo. [/b][/quote] You don't squeeze nitrous...you spray nitrous, dumbass.Go jump off a bridge. |
#16 |
You must be watching too much FnF and playin GT3 too much. squeezing is a term for using nitrous, your still wrong you dont squeeze boost. End of story, Im no longer repling you can argue with your self.
#17 | ||
Nice primer on your hood makes it look like a carbonfiber hood from a far (NOT). Your moma = whore of the month . Since nitrous is already suppling oxygen to the chamber it needs to exit. Nitrous needs exhaust valve to open wide if thats done with a turbo you lose boost and overlap will cause pressure to reverse. wow b16 in a sedan, hoping to make some passes? I have a stock CRX HF in the garage that has been sitting for 3 month that would start up and walk that thing. |
#18 | |
2265787829
#19 | |
Me = ![]() ![]() |
#20 | |
2265787829
Me = [/b][/quote]funny you have no arguement cause I'm right |
#21 | ||
Member of the 20 nut club
we have established that that was the sentance that made you think he was thinking of running nitrous now he has since clarified the misunderstanding by stating that he was refering to boost not nitrous maybe his wording was not the best maybe you read into it and saw something that was never there in the first place just shut the fuck up and move on with your life __________________
МОΛΏΝ ΛΑΒΈ |
#23 |
2265787829
Dude. you're being of NO help to me. You've done nothing but annoy me and waste everyones time with your pointless dribble. Stay out of my thread.
#24 |
werd icy winds input has been nothing but incorrect offtopic and worthless. YOU SUCK ICY WINDS!!! take your worthelss incorrect info somewhere else
94 Honda Accord, jdm h22 swapped daily driver 04 cbr600rr fun toy 95 toyota tacoma, lifted winter truck |
#25 | |
| 95 hatch, b18c1 jdm engine | VTECPOWER | HYBRID -> EG-EK / DC | 6 | 04-08-2004 12:37 AM |
| b18c1 in a hatch.. I have some questions | Rex | HYBRID -> EG-EK / DC | 6 | 01-08-2004 09:22 PM |
| b18c1 in a hatch....i ahve some questions | Rex | HYBRID -> ED-EF / DA | 3 | 01-08-2004 02:03 AM |
| Anyone here? | 2000Si | Members' Lounge | 14 | 12-09-2003 11:55 AM |
| B18C1 into a 93 si hatch | Qwikcivic | HYBRID -> EG-EK / DC | 5 | 11-11-2002 10:18 AM |
