B18c1 OBDII v.2
Old 10-23-2003, 01:38 AM   #1
Rep Power: 0 spOonPLS. is off the scale
Can a b18c1 obd2 v.2 fit in a 99-00 civic hatch with no problem.....i know it plugs right in but i was wondering if i need different motor mounts. I'm sure you guys heard this question before, but i could not find the answer. I know that 96-98 hatches need a si rear motor mount only and everthing else drops right in.....thanks for your help.....
spOonPLS. is offline   Reply With Quote
Old 10-23-2003, 11:16 PM   #2
bump
Old 10-23-2003, 11:18 PM   #3
Rep Power: 24 highperboi is off the scale
Send a message via AIM to highperboi
arnt the 96-00 the same?
and i think the civic driverside mount is different so maybe get a 99-00 si braket?
my <a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=668\' target=\'_blank\'>civic</a> can burn stationwagons.....when they're parked
highperboi is offline   Reply With Quote
Old 10-23-2003, 11:30 PM   #4
Rep Power: 0 Brent is off the scale
I just installed a b16b(civic type r) into a buddies car (a 1999)the wiring harness needs some modification some of the sensors on the stock harness go to differnet spots on any b series ecu the alternator plugs are differnt so u have to use the plug from the gsr motor and they may be a extra wire that will need to be clipped it goes to the ecu it is not really importan. the rear tranny mount must be a sir mount from 99 up Only no other mount will fit without a lot of modification u will need the front tranny mount as well from a sir and the drivers side top mount will also need to be changed. u will need to unbolt the timming cover and remove it from behind it simply changing the top peice of it wont work u need the whole thing trust me. if u want email me for more info i have a lot of experience withe honda swap i ahev doen like 12 so if u want i can get u all the wiring u wil need and tell u how to do it. peace
brent_hawke@hotmail.com
Brent is offline   Reply With Quote
Whats a difference between B18C5 and B18C1 hondacivicnos HYBRID -> EG-EK / DC 11 10-28-2007 07:27 PM
b18c1 worth the $1200 more than b16? solutionzero HYBRID -> EG-EK / DC 12 06-11-2004 06:13 PM
OBDII B18C1 Distributor with OBDI Ecu? RiceBurner98SC HYBRID -> EG-EK / DC 6 07-08-2003 11:33 PM
Were Can I Buy B18c1 Obdii hondacivicnos HYBRID -> EG-EK / DC 2 04-07-2003 09:57 PM
Will Obdii Dist. Work? dkasakitis ECU's, Electronics, and Tuning 2 01-29-2003 09:28 PM
